Old 06-07-2011, 03:31 AM   #1
Clutch442
Clutch442's Avatar
Thermostats
What brand of thermostat are you guys using? I would prefer one you can get locally at an auto parts store. I had just the standard issue Murray and it doesn't hold a temp for 10 cents. I put one of the Stewart Components Robertshaw's in it this weekend. Now it won't run over 112 degrees, even after idling for an hour. Advice appreciated.
Clutch442 is offline   Reply With Quote
Old 06-07-2011, 10:38 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Thermostats
I use whatever my local NAPA store has... I think it's a Stant. Not sure because I haven't needed a new one in several years.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-07-2011, 11:40 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Thermostats
In this area, NAPA is not what it used to be so I just buy mine at the local auto parts stores like Auto Zone, Oreilley's or Advance.
I've had some bad ones from all of them so if you suspect the thermostat, test it by heating it in an old pot with a thermometer to check the water temp when it opens.
68gmsee is offline   Reply With Quote
Old 06-08-2011, 12:52 AM   #4
slikside
slikside's Avatar
Re: Thermostats
I just put one in from NAPA. The small print on the packaging said Stant.
slikside is offline   Reply With Quote
