Old 06-07-2011, 11:28 PM   #1
lsteiner72
CPP Drop Spindles hitting upper control arms
Hi guys,
I installed my drop spindles from CPP and the steering is bound right tight, after looking at it, the upper control arm is hitting the top ball joint perch.
Has this been seen before? How have people remedied this?.
Lucas
lsteiner72 is offline   Reply With Quote
Old 06-07-2011, 11:58 PM   #2
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: CPP Drop Spindles hitting upper control arms
Are they cpp or western if western brand I have seen it before I just removed a little of the upper with a cut off wheel
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 06-08-2011, 12:28 AM   #3
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
I have westerns from CPP and without the weight of the motor etc over them mine do the same, worst case you will have to do as mentioned before, it's not a major but if they're already painted it's frustrating
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-08-2011, 09:15 AM   #4
ldgn63
Originally Posted by tantrumpipeline View Post
i have westerns from cpp and without the weight of the motor etc over them mine do the same, worst case you will have to do as mentioned before, it's not a major but if they're already painted it's frustrating
ditto!
ldgn63 is offline   Reply With Quote
Old 06-08-2011, 09:43 AM   #5
lsteiner72
awesome.... yep already painted and mounted, cotter pinned and greased why not just make a product that works ....
losing a little more faith in CPP every time I deal with them...
Old 06-08-2011, 01:31 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
Just make sure you have the correct upper ball joint in place as well. A ball joint with the wrong taper can allow the upper arm to sit closer to the spindle.
If it's just the matter of a fat casting on the spindle... grind away. Definitely not fun if you have already coated and finished the parts.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-08-2011, 01:49 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i heard they made new upper shafts for the upper a arm
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-08-2011, 02:13 PM   #8
lsteiner72
I'm 99% sure I have the right ball joint, it's a 70 and pretty sure these spindles were supposed to be good for the 70 ball joint.
Fastwillie what do you mean by new upper shafts? Is there supposed to be any differences in them from the originals? I put new MOOG ones in all arms already.
Old 06-08-2011, 02:16 PM   #9
ds350
Just when through the same thing, a few minutes with the grinder using a flap wheel took care of it.
ds350 is offline   Reply With Quote
Old 06-09-2011, 01:23 AM   #10
Tmend
Tmend's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1305085285 check out my pic I have the same problem and boughtbthe same CPP drop spindles. I tried diff ball joints and no help it hits when I air up the suspension. Grinder would suck parts are powder coated. I called CPP and got no help I even ended up buying there ball joints and no good. I just figured I wouldn't drive it at full lift anyway but still bothers me
Some progress is better then no progress
Tmend is online now   Reply With Quote
