Old 06-08-2011, 03:41 AM   #1
ppbr2001
ppbr2001's Avatar
Normal???
Water pump leaked a bit after installation. Stopped after awhile. Is this normal for a new (actually reman) water pump?
ppbr2001 is offline   Reply With Quote
Old 06-08-2011, 07:56 AM   #2
sumran
sumran's Avatar
Re: Normal???
Where is it leaking? Shaft? between pump and block? around hoses?
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 06-08-2011, 08:05 PM   #3
ppbr2001
ppbr2001's Avatar
Re: Normal???
Couldn't really tell. It was running down the front of the motor. All I know is it stopped.
Old 06-08-2011, 09:25 PM   #4
str8axle55
Re: Normal???
I wouldn`t call that normal. Are you sure it wasn`t just residual coolant?
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 06-08-2011, 11:55 PM   #5
ppbr2001
ppbr2001's Avatar
Re: Normal???
It sure coulda been.
Old 06-09-2011, 12:15 AM   #6
rayfinseats
Re: Normal???
I would keep a close eye on it. If it leaks any more you have issues. If it aint broke don't fix it.
rayfinseats is offline   Reply With Quote
Old 06-14-2011, 07:04 AM   #7
ppbr2001
ppbr2001's Avatar
Re: Normal???
Can't see it leaking anywhere but the fluid is going somewhere. Not in the oil pan (checked it 1st!!). Radiator drops about 6 inches to work and the same back. That's about 15 miles round trip, about a gallons worth. Any ideas?
Old 06-14-2011, 07:39 AM   #8
85_C10_Sleeper
85_C10_Sleeper's Avatar
Re: Normal???
If its leaking, pull it off, get new gaskets. Get a can of high tack valve sealant. Clean it up really good. And put it back together. I had no leaks when I installed mine and still don't several months later.
85 C10 LWB
305ci - 700r4 - 10 bolt - 3:08 gears
Collecting parts for a 'mild prerunner"
85_C10_Sleeper is offline   Reply With Quote
Old 06-14-2011, 08:11 AM   #9
ppbr2001
ppbr2001's Avatar
Re: Normal???
Sealer on bolts too?
Old 06-14-2011, 08:12 AM   #10
ppbr2001
ppbr2001's Avatar
Re: Normal???
Really confusing me cause it don't leak while sitting.
Old 06-14-2011, 08:49 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Normal???
A few years ago in the fall i had changed the water pump late into the night on my 89
used water checked it for leaks with water went to bed
woke up the next day ran the truck down the street to get anti freeze
the block froze and cracked leaked all over
mine cracked around the engine mount but the leak came out the bottom in the same area
hope yours has another reason,like just a bad rebuild
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-14-2011, 09:39 AM   #12
85_C10_Sleeper
Re: Normal???
I just put it on the block, and the water pump that was it. and then put the gasket in between, dont over do it of course. But high tack gasket sealant is tons better than rtv sealant, and a million times better than that orange rubber S***.
Did you buy a rebuild or a brand new one?
85 C10 LWB
Old 06-14-2011, 01:07 PM   #13
ppbr2001
ppbr2001's Avatar
Re: Normal???
Oreilly's rebuild.
