06-09-2011, 11:46 AM | #1 |
1972 axle 1969 truck
Hey all I'm a newbie here and need a little help. I have a 69 short wheel base 2wd with a 12bolt rear 6lug. The truck has drum brakes all the way around. I purchase a 72 long bed 2wd as a donor vehicle, it's 5 lug. I understand how to swap out the fronts so I'll have disc brakes on the front of the 69 while at the same time converting it to 5 lug. However on the rear, I know I can't just swap axles because the 72 is roughly 2 inches wider drum to drum and the bearing will ride in the wrong spot. What I'm asking is... what if I just swap the entire axle assembly, is there any downfall to that? Seems the rear being a bit wider would be better, not to mention the bigger drums would be beneficial as well?? I know there is a kit to convert the rear to 5 lug; but swapping assemblies would be cheaper for me since I have the complete 72 rear.
thanks in advance |
06-09-2011, 11:55 AM | #2 |
Re: 1972 axle 1969 truck
I see I posted this in the wrong spot.
sorry. Please move to engine and drive train. |
06-09-2011, 12:22 PM | #3 |
67-72 parts collector,…
Welcome to the board!
Swapping the entire rearend from the '72 would be the most affordable way to get 5-lug wheels on the back of your '69 truck. People do it all the time.
06-09-2011, 02:00 PM | #4 |
Thanks Keith, I just wanted to make sure there were no downfalls from doing that... I couldn't see any myself, but wanted to ask the pro's.
thanks again. |
06-09-2011, 04:14 PM | #5 |
There might be a slight difference in the rear rubber brake hose, or connection point.
Nothing that can't be easily fixed.
Tags |
5 lug, 6 lug, 67-72 chevy, axle, swap |
