Old 06-11-2011, 12:41 PM   #1
Tbruz
Steering column help
Greetings,
1972 Blazer with manual trans and no tilt.
Decided to replace the aftermarket steering wheel with a stock one.
Used a puller with no issues to remove.
Upon removal; i can feel the exposed part of the steering shaft moving form side to side, about a 1/4" or so.
Replace with stock wheel and play is still there; turn sig and horn work.
As I start to go for a drive and turn the wheel I can hear the horn activating as the wheel moves side to side.
Is there a exploded view of a stock column somewhere?
Is there a bearing up top that I trashed in pulling the non-stock wheel?
Any ideas appreciated.
Thanks,
Tony
Tbruz is offline   Reply With Quote
Old 06-13-2011, 01:18 PM   #2
Tbruz
Re: Steering column help:update
Update:
Found the top bearing trashed.
Does anyone have a Manufacturer or P/N for a .75" ID x 1.25" OD .250 thick bearing.
No Joy from local part stores.
Thanks,
Tony
