Old 06-15-2011, 12:29 AM   #1
bucannon
Salty Sailor
bucannon's Avatar
Cool 73-87 lift spindle installation in the 86 Custom Deluxe
i have finally gotten the time to install my lift spindles. they are 1988 - 1998 Chevy 4 inch lift spindles.
my reason for lifting is that i use my truck as a work truck. So i really could use the extra ride height and "long travel" with some big tires which will improve ride quality. I opted to keep the stock coil springs as they are not stiff springs and that will keep it smooth on the road.
the parts list so far is:
  • 1973 - 1987 3/4 ton lower control arms
  • 1988 - 1998 upper ball joints
  • 1988 - 1998 outer tie rod ends
  • 1988- 1998 rotors and calipers
so with all my parts here or on the way, i began
Just wanted to say i used Rock Auto to order all my parts because even with shipping, they are usually less than half the price Autozone/Advanced/Oreilly or other stores.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 06-15-2011, 12:39 AM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: 73-87 lift spindle installation in the 86 Custom Deluxe
here is the drivers side mocked up without the spring installed
Savannah, Georgia
Old 06-15-2011, 01:22 AM   #3
bucannon
Salty Sailor
bucannon's Avatar
more pictures
here is the 88-98 upper ball joint. it fits right where the old one did luckily!
The Rock Auto lower control arm "dent" next to the shock mount wasnt as deep as the original so i had to get the air chisel out and modify it to allow the bolt to fit.
Savannah, Georgia
Old 06-15-2011, 01:33 AM   #4
y5mgisi
Second Chance Program
y5mgisi's Avatar
Very interesting. Cool stuff! Im interested to see how it turns out!
y5mgisi is offline   Reply With Quote
Old 06-16-2011, 12:38 AM   #5
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: 73-87 lift spindle installation in the 86 Custom Deluxe
I Made alot of progress on the passenger side today. but snce my internet is slow i cant upload very many of the pictures i took.
but i have the passenger side mocked up and il be putting the spring in tomorrow
i will also hopefully be getting some 1988 - 1998 rotors and calipers from the junkyard tomorrow too.
not sure if i will need brake line extensions yet but it looks like i might
here is a picture i managed to upload comparing the old lower ball joint to the new one. more pictures to come when my internet isint so slow!
Savannah, Georgia
Old 06-21-2011, 03:25 AM   #6
bucannon
Salty Sailor
bucannon's Avatar
i have almost finished.
i used 3/4 ton heavy duty brakes so my original plan to use 15 inch rims would not work. so i bought a set of 17 stock bullet hole style rims from a buddy.
they look like this except with GMC center caps
Savannah, Georgia
Old 06-21-2011, 11:11 AM   #7
Cherub
Cherub's Avatar
Originally Posted by bucannon View Post
more pictures
I need to do this to my LCA cause its a pain to put the bolts in.
Cherub is offline   Reply With Quote
Old 06-21-2011, 11:40 AM   #8
rocking chevy
rocking chevy's Avatar
If you don't mind me asking, how much did the lift spindles cost, and how much did everything else cost?
rocking chevy is offline   Reply With Quote
Old 06-21-2011, 09:34 PM   #9
bucannon
Salty Sailor
bucannon's Avatar
lift spindle set $250
the lower control arms $89 each
ball joints and tie rods about $60
having a one of a kind truck: Priceless
as for rotors and calipers i recommend hitting up your local junkyard, get 3/4 ton stuff
Savannah, Georgia
Old 06-21-2011, 09:48 PM   #10
bucannon
Salty Sailor
bucannon's Avatar
got the wheels mounted using washers as wheel spacers haha
Savannah, Georgia
Old 06-21-2011, 10:33 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I really like what you are doing here. For those of you that like what you see, there is a great article on this topic in our FAQ forum. Take a look at "73-87 2wd lift with 33x10.5x 18 Nittos"
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-22-2011, 08:35 PM   #12
rocking chevy
Thanks a lot man, its looking great, and should ride good.
Old 08-14-2011, 10:36 PM   #13
rocking chevy
Anymore progress on this?
And what size tires are you running?
Old 08-18-2011, 11:04 PM   #14
Suburban_Tyler
Suburban_Tyler's Avatar
  • 1973 - 1987 3/4 ton lower control arms (or just ball joints)
So the lower control arm has to be changed or can just the lower ball joint be changed? I see the taper is different on the two. Is the lower ball joint you used from a 88-98 or 73-87? I want to do this set up to my suburban.
I was reading on another forum that a guy used 1 ton lift spindles and switched to 8 lug. Any info on swapping to 8 lug? Of course the rear end is easy enough
Suburban_Tyler is offline   Reply With Quote
Old 08-19-2011, 07:56 AM   #15
rocking chevy
do you know whats different about the lift spindles, for 1/2 tons , and 1 tons? If there the same then all you need is different rotors that are 8 lug, if there different then you need 1 ton lift spindles, and 8 lug rotors.
Old 08-22-2011, 10:30 PM   #16
Suburban_Tyler
Physical difference I don't know the difference. They do show a different part number for the 1/2- light duty 3/4 ton to the heady duty 3/4 to 1 ton. All I've gathered so far just from looking up parts is that they use the same lower ball joint. Upper is different but only difference I can see just from pictures is the mounting surface. From the pictures I have looked at the upper control arm is made up different between the two as well. I just happen to look at a buddy's 1/2 ton 4wd upper control arm this weekend and it looked like it was the same as the heavy duty 3/4 and 1 ton 2wd. I'll have to check it out. I'm sure it will lead to nothing but anything is possible.
Old 08-23-2011, 08:26 AM   #17
rocking chevy
if all you need to make it work is the upper control arm, then thats easy.
Old 08-23-2011, 08:54 AM   #18
Suburban_Tyler
I haven't looked to hard yet but I havent even found a lift spindle for a 2wd heavy 3/4-1 ton 92-98 yet. Upper 4wd 1/2 ton and 2wd 1ton ball joints are different in 1993.
Old 08-23-2011, 04:24 PM   #19
joe231
joe231's Avatar
cool build!
What is your plan for the rear?
Can you clarify this
The 6 lug stuff is the light duty 3/4 ton.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-23-2011, 07:12 PM   #20
Suburban_Tyler
Originally Posted by joe231 View Post
cool build!
I'm curious on the brakes too. I'd say he would just use 4wd axle shafts in the rear.
Old 08-24-2011, 12:27 AM   #21
bucannon
Salty Sailor
bucannon's Avatar
okay sorry about taking so long to respond i have been at sea for two months with Texas Maritime Academy. taking classes and working towards my 3rd mates license.
but the 88-98 1 ton spindle is different as i tried to use a 2500HD 13 inch 8 lug rotor and the bearings were too big for the spindle. im sure they make a 1 ton lift spindle.
the "3/4 ton" brakes are from that same 2500 truck with the 13 inch rotors. they fit the spindle and the 11" rotor. the advantage is bigger pads and a larger bore on the cylinder.
as for the lower ball joint. it is a 73-87 3/4 ton. you can keep you original lower control arm and i almost wish i did because i have to take it all apart again to modify the Rock Auto lower control arms again to get them to center up [ i will explain this in detail in a later post].
the upper ball joint is the 88-93 i used 1/2 ton. but i am worried that i may have needed 3/4 ton. but i will find out soon if this is true.
for the rear i plan to use 5 lug to 6 lug adapters.
i need spacers for the front because i chose to use 17" 2007 stock bullet hole style rims from a buddies GMC. i will post pictures soon
i also plan to eventually get a set of 35 inch tires. that is after i buy the spacers and adapters.
once again sorry i took so long to respond!
Savannah, Georgia
Old 08-24-2011, 12:33 AM   #22
joe231
joe231's Avatar
No worries!
So the calipers are from a 2500HD and they fit the 2500LD rotors?
How much lift do the spindles give you? Are you going to run lift blocks in the rear?
CHEVY ONLY
Old 08-24-2011, 12:36 AM   #23
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
you say you can keep the original 1/2 lower control arm?
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 08-24-2011, 12:41 AM   #24
bucannon
Salty Sailor
bucannon's Avatar
No worries!
that is correct. i could not believe it myself but after i put it all together it worked and the pads line up exactly where they should on the 11'' rotor.
the problem was after i did this the 15" 6 lug rims i picked up would no longer fit so i had to hurry up and find some rims that fit before i went out to sea so it would at least be a roller. luckily my buddy just put new rims on his truck so i picked up the stock 17's with two tires still holding air and equal in size to my old 33's.
Savannah, Georgia
Old 08-24-2011, 12:43 AM   #25
bucannon
Salty Sailor
bucannon's Avatar
i gained about 5 inches of lift in the front.
i used 3 inch blocks and it sits nose up about 1 inch. looks cool kinda like a pre runner. the 2 off road lights i put on the front bumper help too.
Savannah, Georgia
2wd lift, 73 - 87 lift kit, bucannon, lift spindle
