Old 06-15-2011, 09:26 PM   #1
Gene Stevenson
wiring harness 66 truck
How do you decide which wiring harness to buy? is one brand better than the other. I have a 66 suburban and need all new wiring.
Gene Stevenson is offline   Reply With Quote
Old 06-15-2011, 10:34 PM   #2
dtkarst
Re: wiring harness 66 truck
I just bought a painless wiring harness through jegs just last week. All the wires are color coded like factory and seems to be pretty simple to install (this weekends project) but thats my 2 cents
dtkarst is offline   Reply With Quote
Old 06-15-2011, 11:08 PM   #3
Clyde65
Clyde65's Avatar
are you going original or custom, meaning ac, radio, power other stuff, seats etc?
Either way, dont spend money on the cheaper harnesses, go with AAW ( American Auto Wire. MGBMike has them very reasonable, he is on the board here.
Ive done the cheap ones and ended up doing the AAW Classic Highway series.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-15-2011, 11:48 PM   #4
jocko
jocko's Avatar
if not a stock restoration - I personally like the ones that have the circuit name printed on the correctly color coded wires (i.e. "ignition" or "water temp sender" or whatever) - so instead of having to squint at a wiring diagram, your wire bundle is its own wiring diagram. But might look a little hokey - depends if you're a form over function sorta guy or the reverse. At a minimum, I'd make certain it's gm circuit color coded - and most of them are. Having said all that - I concur with Clyde, have heard nothing but good stuff about AAW. For that matter, have never heard anything bad about Painless either...
Old 06-16-2011, 08:38 AM   #5
gtbrain
My 66 was totally gutted of wiring. I went with the 9+3 Rebel Wire package. It worked for my needs very well since I was not looking for an original rebuild. And excellent customer service.
http://rebelwire.com/rebel-wire-prod...at=Wire%20Kits
gtbrain is offline   Reply With Quote
Old 06-16-2011, 08:51 AM   #6
lakeroadster
Here is a previous thread on this very subject: The Wiring Harness Thread
lakeroadster is offline   Reply With Quote
Old 06-16-2011, 12:42 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
If you're looking for a product review...I've wired several trucks and hot rods using Ron Francis kits and they are by far the best that I've used, along with excellent service.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-16-2011, 01:01 PM   #8
jimmydean
jimmydean's Avatar
This is the kit I will likely run. I have used a few different kits and to be honest, I didn't see a huge quality difference vs. Painless minus the price. We used a cheap universal in a friends '67 Bronco over 10 years ago and it's going strong without issues. The truck gets beat on constantly, too.
If my truck is still with me in 10 years, I will be surprised. Quality installation is nearly half the battle.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
