Old 06-16-2011, 11:27 PM   #26
JMR5
JMR5's Avatar
Re: anybody used this dual master cylinder bracket?
Originally Posted by tmoble View Post
anyway, back to OP, anybody used that master cylinder mount?
Yes, I used that bracket and it has worked fine. I used a dual master out of an early 70's malibu or nova I believe. The part number was M1505.
JMR5 is offline   Reply With Quote
Old 06-17-2011, 01:16 AM   #27
tmoble
JMR5
Can you put fluid in it OK? Have to go through some gyrations? Are you using disc/drum?
tmoble is offline   Reply With Quote
Old 06-17-2011, 09:17 AM   #28
JMR5
JMR5's Avatar
I can still get fluid in the master cylinder through the stock hole in the floor. I used a bottle with a little hose on it to make it easier. You can always cut your floor a little and use one of the larger rectangular hinged doors if you want even better access. I'm still running drum/drum and that is what the master cylinder I bought was designed for. If you run disc/drum you'd need to use a diff master than what I used.
Old 06-17-2011, 11:29 AM   #29
tmoble
sounds good to me. Thanks for taking time to respond.
Old 06-17-2011, 03:42 PM   #30
OrrieG
OrrieG's Avatar
Or make one for under $10. You can see the mc lid in the right photo. Note I set my seat up so I can tilt it up to get access to the door, if your seat is fixed you might want to locate it on the other side of the floor brace.
Old 10-02-2011, 04:04 PM   #31
Coupeguy2001
Coupeguy2001's Avatar
I hacksawed the bottom off of the original master cylinder which allowed the use of a 90 degree bracket made from 1/4" plate to bolt to the frame and master cylinder/hydroboost unit. the pedal support pivot is the top half of the old master cylinder. I cleaned it up on the grinder, and it doesn't look half bad. It even has a groove cast into it that the shaft uses for clearance.
Now I have a little place to keep a cash stash! lol
I bought a rebuilt hydroboost at the Good Guys show for $100, an a mastercyl. and hydroboost unit for $60 off craigslist. Now I have a spare for rebuilding.
Yea I know this is an old thread, I just found it.
Coupeguy2001 is offline   Reply With Quote
