06-17-2011, 12:16 AM | #1 |
Stock plug wire set
I'm converting my '70 suburban from HEI back to stock single points--yeah, go back and read that again--but am unsure of where to get a wire set that will fit properly. The engine is out now, it is basically stock with ALL of the stock clips and looms. I know I will have to cut and crimp on one end. My concern is that to run them properly they have to be very long, and in this day and age we never seem to get any extra material. Any recent sets I have bought included some very short wires for the back cylinders that definitely won't work with a stock application here. Skinny black wires are preferred. Any help appreciated.
I know about Pertronix, etc. I'm going to use points. |
06-17-2011, 01:19 AM | #2 |
Hand Crafted C-10
Re: Stock plug wire set
I would look into maybe a '66 Corvette.
NAPA carries MPW 2821, which is routed below the manifolds and, I think, were pre-HEI. No promises but that is where I would start. |
06-17-2011, 03:00 AM | #3 |
~Rest In Peace~
you can get the wire in bulk and make your own wire set its easy
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-17-2011, 05:43 AM | #4 |
There are companies that make the exact stock wires that will route in the stock location which is under the manifolds and the fronts actually come up and through the motor mount pad. The wires have the correct date codes and are labeled as original- Packard wire. I have used these twice, once on my factory bb 71 (which has the correct hoses etc,etc) and on my 4x4. I can post pictures if you would like and I will check on the company as well. The wires are expensive and are not the generic parts house wires. Expect to pay from $65-$80 for them. I will post pictures later this morning.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
06-17-2011, 06:34 AM | #5 |
Watch out for your cornhole !
I've had fine luck with most any good brand of stock wires. Borg Warner is who I've been using the last few years. They go up under the manifolds and fit the factory looms.
06-17-2011, 07:21 AM | #6 |
I would get genuine Delco wires-try Advance, O'Rieleys, or GM dealer. Next choice would be MOROSO Blue Max wires. All would be precut and ready to go. I do not like crimping the ends.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-17-2011, 08:37 AM | #7 |
Thanks guys, I will explore all these options. I have had such bad luck at the generic stores that I'm always leery. I'm sure they have the set I need, the question is whether the guy behind the counter can find them. And $65-$80 wouldn't be too much to pay, especially if they were fitted. This is not a technically correct resto, but I want it to be stock-appearing.
06-17-2011, 08:58 AM | #8 | |
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
