Old 06-17-2011, 11:52 AM   #1
2mas
VIN vs, motor type
Hi!
Any one thay can help me? How can I figure out what engine type was fitted originaly in a C10? I was thinking of exporting a 63-66 with V8, but need to be sure of that being originaly installed. There are no requirement for matching numbers but cylinder count and cubic inch need to be original!
Thanks!
/2mas
2mas is offline   Reply With Quote
Old 06-17-2011, 01:09 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: VIN vs, motor type
As far as I know there is no way to determine what motor a truck came with. It may have a build sheet on the glove box door stating it but they are only on 66 and usually gone.
LT1 Burb is offline   Reply With Quote
Old 06-17-2011, 03:13 PM   #3
2mas
Ok! thx.
What is diffrent on the truck if a V8 was installed from beginning? Brakes?
/2mas
Old 06-17-2011, 03:27 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
This may help, but does not specify engine.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=9
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-17-2011, 08:41 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
if you are lucky there is stil a build sheet under/behind your seat. otherwise there is no way to tell.
the v8 does use a shorter gas pedal lever on the firewall side, that might be your only clue.
since there is no way to tell for sure, all 63-66's were available with a 283 3bbl , if it was ordered with a v8. some were special ordered with a 327, but every "327" 60-66 I have bought , or looked at turned out to be a 283.
you can have the seller send you the #'s from the front right pad in front of the cylinder head, that will give you the year and type of engine... for example I looked up the "327" in my 66 and it turned out to be a 66 283 2bbl california smog motor, which was further proved by the still original pass. side exhaust manifold that had the air ports.
Old 06-17-2011, 10:15 PM   #6
RandyDandy
block i.d.Name:  endinedetail1[1].jpg
RandyDandy is offline   Reply With Quote
Old 06-17-2011, 10:19 PM   #7
jocko
jocko's Avatar
jonz - I always thought the 327 was only an option in 66? Was it available in other years?
Old 06-18-2011, 02:59 AM   #8
collins10672
collins10672's Avatar
the vin does not tell what engine came in these trucks.as stated above the best way to know if the engine is the correct year is to run the numbers on it.although you might have a 66 engine in a 66 truck it still might not be the original engine for that truck.there is really no way to tell if it came in a particular truck or not even if you have the build sheet the engine could have come out of a parts truck that is the same year.the 1966 trucks were the only year with option label attached to inside of glove box and these can be reproduced to state that a truck had options that it did not originally have.i would say that if you have a 66 engine in a 1966 truck that would be as close to original that you could get in these trucks.good luck.
collins10672 is offline   Reply With Quote
Old 06-18-2011, 07:27 AM   #9
jonzcustomshop
1961 crewcab
my 1964 owners manual shows the 327 as an option, but it looks to only be available for the c/50 and up.....
I do think in those years the dealer could special order stuff like that for the 1/2 tons...
Old 06-18-2011, 11:09 AM   #10
kieth
kieth's Avatar
My 66 gmc has the engine hp and model, along with where it was built (pontiac Michigan) along with the GVW. Here is a picture of that tag......the flash is over the Pontiac MI build plant info:
http://kieth.smugmug.com/Trucks/66-G...749_AVav7-A-LB
I have another 65 gmc it has the same tag (drivers side next to vent)
I have a 65 C10 (1 owner original truck) It has a simalar tag but it looked to show more detail I will get my bifocals and look at it again and take my camera out and take a picture of it. Kieth
kieth is offline   Reply With Quote
Old 06-18-2011, 11:30 AM   #11
kieth
kieth's Avatar
Ok this should end the debate about how the cabs were marked in 1965 and what engine was available:
This data tag off of my 1 owner 65 C10 show 283 and the 327 were available in a half ton truck......
http://kieth.smugmug.com/Trucks/65-C..._WgDsDZx-X2-LB
Old 06-18-2011, 01:45 PM   #12
padresag
that is just a general tag that will work in all models. It just has the gvw stamped to match the applications
the 327 was 1966 light duty. you have never seen a 4 cyl 153 cu.in. in one of our trucks either have you? that is also on the plate!
ron
padresag is offline   Reply With Quote
Old 06-18-2011, 06:56 PM   #13
yelmer
if you have the vin number and the engine stamp from the pad you can get within a month production . the 66 327 was yh yc ys stamp code . i have production data from st louis fremont flint janesville tarrytown atanta and baltimore
yelmer is offline   Reply With Quote
