Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-17-2011, 06:56 PM   #126
bruin_d
bruin_d's Avatar
Re: 72 Suburban Build
Originally Posted by jmedero View Post
Oh I am interested to see how you are going to do the filler neck for the fuel. I used my factory tank just mounted it on top of frame. I think the angle of the neck to the tank on my set up is going to be too sharp on my set up.
I'm basically going to cut the stock filler tube down right after the taper. Then I'll make my own tube. We'll see if/how it works. In my head its going to work fine...but you know how that works. I jst need to make sure I have a good enough height difference to fill it. Otherwise I'll have to let the passenger side bags down whenever I fill up
bruin_d is offline   Reply With Quote
Old 06-17-2011, 08:04 PM   #127
jmedero
jmedero's Avatar
That would be hilarious to see. The old dude at the next pump saying " excuse me sir, I think your shocks are busted"
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 06-17-2011, 10:44 PM   #128
Wildstreak
"something witty here"
Wildstreak's Avatar
Ok, don't tell me you still haven't gotten your motor mount yet? Why isn't this bad @ss motor in its home yet?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 06-17-2011, 10:52 PM   #129
bruin_d
bruin_d's Avatar
My radiator that was supposed to get to me in 5 days took 4 weeks and they didn't even send me everything I ordered. My master cylinder/booster setup that I was told would get here in 5-7 days when I ordered it on 5/31...still hasn't been shipped yet. My wiring kit for my accuair stuff that I ordered was never sent to me. I wanted to get all of the wiring and brake stuff done first before I put the motor in but these vendors and their BS shipping promises are killing me.
Old 06-18-2011, 09:16 PM   #130
bruin_d
bruin_d's Avatar
Almost done with rear! I'm very happy with how its turned out. I'm still trying to decide where to mount the valves for the air system.
Old 06-18-2011, 09:31 PM   #131
camping_man
i have a 72 3/4 ton regular cab long bed.can i put a 72 burb on that frame
camping_man is offline   Reply With Quote
Old 06-18-2011, 09:41 PM   #132
bruin_d
bruin_d's Avatar
Short answer...no.
Old 06-18-2011, 10:01 PM   #133
Hart_Rod
Hart_Rod's Avatar
Originally Posted by bruin_d View Post
Short answer...no.
Actually you can..... However, you will have to swap all of the body mounts (except for the very front ones) and you'll have to weld the end of the rear burb frame rails onto the truck chassis if you want to run a burb factory bumper.....
Hart_Rod is offline   Reply With Quote
Old 06-18-2011, 10:11 PM   #134
bruin_d
bruin_d's Avatar
That was my long answer...
Old 06-18-2011, 10:12 PM   #135
Hart_Rod
Hart_Rod's Avatar
Old 06-18-2011, 11:12 PM   #136
jmedero
jmedero's Avatar
Wow that's funny Rob. You and I just had that conversation in my garage today. Tha ks for the visit.
Dude the floor frame looks killer. Your giving me all sorts of ideas. What are you doing for shocks in the rear?
Old 06-18-2011, 11:42 PM   #137
bruin_d
bruin_d's Avatar
The shocks are the ones that Porterbuilt supplies with his drop member setups. I'll have to look at the box to give you a part number.
Old 06-18-2011, 11:54 PM   #138
bruin_d
bruin_d's Avatar
I'm still trying to figure out what to do in the front. Do I make some funky angles to makethe stock back seat bolt up? Do I make it simple and then just get some bucket seats or something?
Old 06-19-2011, 12:31 AM   #139
jmedero
jmedero's Avatar
Dude two buckets up front and in the rear. Then one nice long console.
Old 06-20-2011, 11:52 AM   #140
67cheby
67cheby
67cheby's Avatar
LOOKING GREAT man !!
67cheby is offline   Reply With Quote
Old 06-20-2011, 08:01 PM   #141
bruin_d
bruin_d's Avatar
Pretty productive day. I moved/added my filler tube to the side of the tank in an attempt to use the stock location. I cut all of the sheet metal for the floor and started welding it down. I used 16ga which should be plenty strong, however, it is a PITA to cut.
Old 06-20-2011, 08:25 PM   #142
jmedero
jmedero's Avatar
Hope the tank works out for you dude. The floor looks great.... I need to get busy. Lol
Old 06-20-2011, 08:53 PM   #143
bruin_d
bruin_d's Avatar
I hope so too. I left the top fill spot there for now just in case it doesn't work out. If it works, I'll cut it out and patch it up later. I probably would've finished it all but it was 110 degrees today with the heat index. I was struggling.
Old 06-20-2011, 09:45 PM   #144
jmedero
jmedero's Avatar
I feel you brother. It was about the same here. Kind of hard to come home and jump back out in the heat. I own an auto detail business so me and the guys are out in the heat all day long.
Keep it up man.
Old 06-20-2011, 10:49 PM   #145
bruin_d
bruin_d's Avatar
Thanks! How are the fenders coming?
Old 06-21-2011, 10:04 AM   #146
67cheby
67cheby
67cheby's Avatar
i emailed the company building them yesterday.....same reply as usual, 2 more weeks .........the owner of the company himself, said he stepped in to finish building my molds himself ! maybe that will speed things up !! waiting is really bad for my A D D !!
Old 06-21-2011, 02:14 PM   #147
bruin_d
bruin_d's Avatar
I would love to do that. Maybe later. I think if I spend anymore money on it I'm going to have to change the title from "72 Suburban Build" to "The Bachelor Maker"...
Old 06-22-2011, 04:55 AM   #148
Mike Bradbury
Mike Bradbury's Avatar
Do you have a place to work on it in San Diego? Can't wait to see it in person.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 06-22-2011, 06:23 AM   #149
bruin_d
bruin_d's Avatar
Yes I do. I have a nice house with a 3 car garage off of Gopher Canyon in Vista.
Old 06-22-2011, 03:22 PM   #150
Mike Bradbury
There is a pretty extensive street cruise up in Escondido weekly. It is a little far for me to go to being down here in east county but the Hot Rod Hauler guys go a lot. I have been having some driveshaft issues I need to work out but I might go this summer a couple of times.
Are you planning on driving the burban out or will it not be together in time?
Mike
