Old 06-18-2011, 12:43 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
90-91 elec. speedo in '88 K5 manual
Before I drive myself insane trying to search for five hours on how I could achieve this, I figured I'd make a thread here.
My plan is to install a '90-'91 electronic speedometer in my '88 K5, which came factory with a TBI 350, SM465 trans, and NP208 transfer case. The original speedo has a trip odometer as well. Last year I installed a clock cluster in it, but kept the trip speedo. Now, I know that the housings are totally different [because I got a cool clock from a Saab that I wanted to replace the old broken Quartz clock with.
I also plan to [because I already have everything for it] swap out the SM465 for another rebuilt one with an NP205 T-case.
If I have to stay with the housing that doesn't have the clock, so be it. Any suggestions?
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 06-20-2011, 01:12 AM   #2
Jonboy
Slots go on anything!
Re: 90-91 elec. speedo in '88 K5 manual
What are you trying to accomplish with the electric speedometer? You will need a VSS and DRAC from a 90-91 to make it work.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-20-2011, 06:42 AM   #3
Rogue_Alphonse
Basically just as an upgrade. My original reason for getting the cluster was for the brake/seatbelt/check engine/4x4 lights. They look cleaner than the older style, where the whole thing lights up rather than just the lettering. I figured the speedometer would be cool as well.
I was trying to skip out on getting parts from a '90-'91 Sub though, one reason is because the cluster I got was already pulled out and sitting in the back of a newer Town Car for some odd reason, and the other is because I have a standard trans, even though that little optical sensor is behind the old speedometer
