Old 06-18-2011, 01:23 PM   #1
DrtyJack75
Blinker Problem -Painless wiring/Summit Chrome Column
Well finally got it all wired up and everything worked....well they wored for about 3 blinks!
Left turn signal blinked 3-4x, Right turn signal blinked 3-4x.....then solid illumination. NO MORE BLINKING!
Hazards work as advertised but now the turn signals just stay on when selected. hmmmmm...
Painless kit is becoming a pain in my arse!! Probably something stupid but with 80%+ humidity and Temps in mid/upper 90s my patience are running thin!!
Any ideas?
DrtyJack75 is offline   Reply With Quote
Old 06-18-2011, 02:17 PM   #2
bmfm64
bmfm64's Avatar
Re: Blinker Problem -Painless wiring/Summit Chrome Column
Swap the blinker flasher and the 4 way flasher and see if the problem happens again or if the 4 ways work fine. I have gone to electric flashers to keep from burning up the old style. Hope this helps.
bmfm64 is offline   Reply With Quote
Old 06-18-2011, 03:27 PM   #3
DrtyJack75
I knew it was dumb....this heat will make you lose your damn mind! I miss Nor Cal!!
Thx!!!
But damn....just notice the head lights don't work. Pulled light switch out and it's hotter than hell!!
Dash illuminates, parking lights all come on....no head lights. Probably not a new problem, never got to them while messing with blinkers....hmmmm
Old 06-18-2011, 04:28 PM   #4
bmfm64
bmfm64's Avatar
I just had both my low beams in my impala go bad after sitting for the winter, I'd check the bulbs first, then the switch. My money is on the switch.
Old 06-19-2011, 11:40 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Are you using LED bulbs?
D.PASSMORE is offline   Reply With Quote
Old 06-19-2011, 07:21 PM   #6
DrtyJack75
well I ordered another switch....so I guess we'll see!
