Old 07-30-2003, 01:42 AM   #1
krazy_texan
krazy_texan's Avatar
raised trucks?
i have a 2 wheel drive truck that i want to lift about 2 inches whether it be suspension or body, it does not matter. would i be able to just put some larger springs in it or would i have to do something else, i know i should be able to put larger spring in the rear without much problem but what about the front.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 07-30-2003, 09:32 AM   #2
krazy_texan
ttt
Krazy Texan
1990 v1500 suburban
Old 07-30-2003, 01:25 PM   #3
GreenMystChevy
Being that it is 2 wheel drive it will have coil springs up front and to my knowledge there is no such thing as 2" raised coil springs for the front.
A 2" body lift should do the trick and is relatively easy. You will run into a few problems such as bumper height, tranny linkage, steering arm, etc. These are all problems that can be solved with a little bit of modification.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 07-30-2003, 02:45 PM   #4
slam33
slam33's Avatar
If you have a SBC in it, you can use BB springs for a 1 1/2 " lift. Anything over 2" and your at the limit of the upper ball joints. As for the rear, if your on coils and have a 2pc drive shaft, you can go about 2 to 3 inches but then you start to pull on the support bearing and it will pull out of the donut.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 07-30-2003, 02:47 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
There are a couple of guys on CK5.com with lifted 2wd blazers. Most are later model ('76+). I don't know how they lifted them or what the differences there are in the suspension.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-30-2003, 04:25 PM   #6
RON WOODGEARD
Resident Young Old Dude !
Krazy_texan,
Do a search here, and you'll find how i did mine. I lost all of my info when my old computer hard drive went south.
I did a 2" suspension and 2" body lift. It enabled me to run 33:10/50 Big"O tires.I used 1964 or 65 Oldsmobile Vista Cruiser 455 front springs. That engine, body/frame combination was helaciously heavy. I have used this spring on many G.M vehicles that I have wanted to raise in the last few decades. It'll get you right at 2", with our trucks and a smallblock. When I had the front end aligned, It was off 1" degree because of the lift. I ran the truck like that for about 8 to 10 years. on and off road. no problems and no noticable sign of premature tire wear.
I have leafs in the rear, I went down toi a sring shop and had them build me some, that would raise the rear 2".
Ron
RON WOODGEARD is offline   Reply With Quote
Old 07-30-2003, 04:31 PM   #7
highboy_04
highboy_04's Avatar
my truck isnt lifted at all and its a 2 wheel drive and i have 33's on it.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
