Old 06-20-2011, 01:24 PM   #126
Bugeyev8
Bugeyev8's Avatar
Re: My 1962 C10 Build Thread "Grandpa's Truck "
Got the hinges worked on yesterday...they were all sloppy..a few hours and a few minutes of frustration finding the parts..I came up with these from Dorman part #38374, its a kit assortment and has 2 of the ones for the 62 ..so I bought as many as I could they only had 2 at one parts house and one at another...then found them at Pep Boys availible seperate but for the same price as the assortment, at 6$ per set its not bad and LMC wanted 9.99 plus their shipping would have been more
I cleaned them up and re used the pin and put a good coat of anti sieze on the pins when I installed them, all hinges like new for under 30$
Bugeyev8 is offline   Reply With Quote
Old 06-23-2011, 07:00 PM   #127
Bugeyev8
Bugeyev8's Avatar
Got some primer surfacer shot today and all the seams sealed
Old 06-23-2011, 07:02 PM   #128
Bugeyev8
Bugeyev8's Avatar
big difference in this and what I started with
Old 06-23-2011, 07:04 PM   #129
Bugeyev8
Bugeyev8's Avatar
more
Old 06-24-2011, 02:33 AM   #130
collins10672
collins10672's Avatar
looking good.i know what you have went through doing this cab sheet metal work i restored a 66 truck back in 1994 and most of the repair panels were not available then and had to be made from scratch including the inner rocker panels.looks like you have done a fine job.
collins10672 is offline   Reply With Quote
Old 06-24-2011, 10:31 AM   #131
Bugeyev8
Bugeyev8's Avatar
That must have been fun, I had to make my own share of patches, I made both inner rockers and the RH floor patch, as well as the corners of the knee knocker cab below the windshield, also made several patches for the hood, Its been a long road..I hope it lasts another 49 years after all this !
Old 07-03-2011, 04:00 PM   #132
Bugeyev8
Bugeyev8's Avatar
Got one more door painted inside and the rebushed hinges painted
Old 07-03-2011, 04:17 PM   #133
Bugeyev8
Bugeyev8's Avatar
more
Old 06-14-2012, 04:47 AM   #134
Bugeyev8
Bugeyev8's Avatar
got the summit headers test fitted...they look ok...kinda cheap and thin flanges, but for 200$ what do u expect ?
Old 06-14-2012, 09:30 PM   #135
Captainfab
60-66 Nut
Good to see you back ....it's been almost a year.
Do you have a part number for those headers? How far down do they hang underneath?
Old 06-14-2012, 11:23 PM   #136
CRGRS 66
CRGRS 66's Avatar
Subscribed, went through the first couple pages, very nice workmanship
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 06-15-2012, 12:06 AM   #137
Bugeyev8
Bugeyev8's Avatar
Made a new trans x member today and started on the exhaust system
Old 06-15-2012, 12:08 AM   #138
Bugeyev8
Bugeyev8's Avatar
Thnaks so very much ! I really appriciate it =)
Old 06-15-2012, 12:10 AM   #139
Bugeyev8
Bugeyev8's Avatar
Yeah went back to work full time and the hiurs are long on top of a long commute, but I had a few days off and got back to the 62 !
The headers are summit long tubes for a 67 camaro , they were 239 $ as I recall, they dont hang too low and for a stock truck like mine plenty of clearance, I can get the part # if you want in a few
Old 06-15-2012, 01:15 AM   #140
Bugeyev8
Bugeyev8's Avatar
pics
Old 06-15-2012, 01:16 AM   #141
Bugeyev8
Bugeyev8's Avatar
pics 2
Old 06-25-2012, 10:49 PM   #142
Bugeyev8
Bugeyev8's Avatar
finished my exhaust tonight, sounds awesome !!
Old 06-25-2012, 10:50 PM   #143
Bugeyev8
Bugeyev8's Avatar
tail pipes, 2.50 mandrel bent pipe
Old 06-26-2012, 09:26 PM   #144
Bugeyev8
Bugeyev8's Avatar
Old 07-05-2012, 08:42 PM   #145
Bugeyev8
Bugeyev8's Avatar
got my belt set up at the pick n pull.....bastards charge an arm and leg for this stuff now!
I am adding AC and needed to relocate the alt to the other side, got a 90s camaro belt set up
Old 09-22-2012, 08:51 PM   #146
Bugeyev8
Bugeyev8's Avatar
Been a while but still working on the 62, been going slow but..the vintage air ac is in and the upper intake is powder costed as well as all accy brackets and pulleys, I get a deal thru work so its better than me cleaning and using a rattle can, cleaning up the engine bay as I go till I blow the body apart and the front clip comes off for paint
Old 09-22-2012, 08:56 PM   #147
Bugeyev8
Bugeyev8's Avatar
pics won't load for some reason
Old 09-22-2012, 09:48 PM   #148
Bugeyev8
Bugeyev8's Avatar
before, I swapped this engine in when I was 17...I just wanted it to run at that time...engine was hi tech then ! I still like the look of the TPI !
Old 09-24-2012, 08:42 AM   #149
Bomp
Bomp's Avatar
Nice work. subscribed.
Bomp is offline   Reply With Quote
Old 12-07-2012, 09:52 PM   #150
Bugeyev8
Bugeyev8's Avatar
not much progress...just doing the easy stuff and thats spending money !
bolts and door parts back from plater today !
1962, lsa supercharger, rust repair, tuned port
