Old 06-21-2011, 11:35 AM   #1
AmesFlames'67
AmesFlames'67's Avatar
Question '67 Steering headache! Frame is 100% flat...
The frame on my '67 stepside SWB is completely flat where the gearbox bolts on. I need to find a Couple-Shaft that will work with my manual gearbox, or figure out the best way to mount a power steering pump from a '71-72.
The Shaft coming from the gearbox is very short, whereas all the other manual gearboxes I've seen have a longer shaft. The part# on the top of my gearbox is 5675569.
I'm wondering if my frame is a '66 with a '67 body? My frame's number is: 6Z143216. If anyone know how to decode that?
Power steering is the way I'd like to go, I have the pump. But since my frame is all flat, I know I'll have to dimple the fame, and use washers to space it. Even the bold pattern on my frame is way different so I'd have to drill some holes to make it work...
If anyone can help me out as to what is up with my manual gearbox, and what coupler I can use to make it work for now, that would be great! Thanks guys.
AmesFlames'67 is offline   Reply With Quote
Old 06-21-2011, 11:41 AM   #2
AmesFlames'67
Re: '67 Steering headache! Frame is 100% flat...
Here's a few pics of what I'm dealing with. I took a grinder to the shafts coming out of the gearbox hoping to use a Coupler shaft from another 67-69 manual gearbox, but no luck... Now I can't count the teeth accurately.
Old 06-21-2011, 03:16 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your easiest route is to use a kit. I used the REZ Engineering kit from Classic Parts for about 60 dollars. It's mainly marketed to the 60-66 guys since their frames are flat also.
It comes with the frame plates you need to bolt the power box onto the flat frame without any dimpling and it comes with the instructions to hook up the column too.
I powder coated mine but here are pictures of the whole deal.
The kit...
http://www.classicparts.com/1960-66-...ctinfo/76-979/
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
coupler-shaft, flat frame, gearbox, power steering pump, steering
