Old 06-22-2011, 11:55 PM   #101
luifer76
luifer76's Avatar
Re: Nobaddaze's 82 C10 Cruiser Build
so when are you gonna build that 4 link bro?
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 06-24-2011, 11:20 AM   #102
Nobaddaze
Nobaddaze's Avatar
Im finalizing stuff right now, hopefully sending some files to my waterjet guy in the next week. Then start ordering some parts
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 06-24-2011, 01:31 PM   #103
luifer76
luifer76's Avatar
cool keep us posted bro...
Old 06-24-2011, 01:59 PM   #104
mcboomport
mcboomport's Avatar
Awesome!
mcboomport is offline   Reply With Quote
Old 06-24-2011, 03:17 PM   #105
Nobaddaze
Nobaddaze's Avatar
will do...
My Build
Old 06-27-2011, 04:11 PM   #106
bmfpeterson
bmfpeterson's Avatar
what up main???? whats the deal I want to see some frame on the ground.....
bmfpeterson is offline   Reply With Quote
Old 06-30-2011, 01:52 AM   #107
Nobaddaze
Nobaddaze's Avatar
Did a little more tonight but time is tight these days...
Whipped up a crossmember too
My Build
Old 06-30-2011, 10:32 AM   #108
luifer76
luifer76's Avatar
that crossmember looks good too man....
Old 06-30-2011, 12:23 PM   #109
mcboomport
mcboomport's Avatar
I would have to say you have to many pieces there. I would lose the c channel piece and bolt it directly to the frame.
Old 06-30-2011, 12:24 PM   #110
mcboomport
mcboomport's Avatar
Originally Posted by mcboomport View Post
I would have to say you have to many pieces there. I would lose the c channel piece and bolt it directly to the outer frame rails.
Old 06-30-2011, 12:29 PM   #111
Pro Performance
Pro Performance's Avatar
I could be wrong, but I think the red c-channels are representing the frame. So his plan is to bolt the green part directly to the frame.
Pro Performance is offline   Reply With Quote
Old 06-30-2011, 12:37 PM   #112
mcboomport
mcboomport's Avatar
The c channel would be reversed then.
Old 06-30-2011, 01:02 PM   #113
Pro Performance
haha.... Yes, you are right. I didn't pick up on that.....
Old 07-01-2011, 01:31 AM   #114
Nobaddaze
Nobaddaze's Avatar
The Red part is bolting to the frame on top and bottom inside the stock frame rails. The reason i did it this way is because my buddy has one without the green pieces. So in order to pull the tranny, we had to "shimmy" (beat on it with a hammer and 2x4) the crossmember back out of the way which sucked while under a bagged truck and trying to support the trans at the same time.
So i made mine to where you can unbolt the green mounts and drop the crossmember strait down and leave the red pieces bolted in place. Seems easier in my head...
does this make sense to anyone else??
Any better ideas??? Im open to constructive critisism, thats what this forum is for...
My Build
Old 07-01-2011, 01:33 AM   #115
Nobaddaze
Nobaddaze's Avatar
heres a pic since my last post didnt load it...Did some work on my bridge setup...
My Build
Old 07-01-2011, 02:09 AM   #116
mcboomport
mcboomport's Avatar
Nice brother! On the crossmember, you don't have to have the plates as big. That way you won't have to shimmy it out. For example, look at my porterbuilt one, It only has two bolt holes on each side. It is about 2 inches where it bolts. This way you could also run your lines easier. Not saying your idea isn't good. I just think it could be simpler and still function.
Old 07-01-2011, 11:10 AM   #117
Nobaddaze
Nobaddaze's Avatar
Damn, that crossmember is way simpler than mine. How easy is the install?
Couldnt find that X-member on nates site, but from the others im guessing it was around 75 bucks?
On a side note...I have my bridge setup with around 8" of notch. I think i read on your thread that you have a total of 7 3/4 notch? My question is that i set mine up to lay stock frame, but your z'd and have a 2x4'd frame. Is my notch too big?
i want just enough to lay frame, so my bed floor is as low as possible.
how tall are your tires?
My Build
Old 07-01-2011, 11:29 AM   #118
Pop's C-10
Pop's C-10's Avatar
I think you can make it simpler, but jus boxing that area & eliminating tha bolt in idea..you can cut tha mounting plates...drill them out..bolt them to tha boxing plate...weld tha bolts to tha boxing plate & weld tha plate to tha frame..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-01-2011, 11:37 AM   #119
Nobaddaze
Nobaddaze's Avatar
That is a good idea, however im trying to do a complete bolt on (no welding to frame) because i have already powdercoated my frame
My Build
Old 07-01-2011, 11:46 AM   #120
mcboomport
mcboomport's Avatar
my notch will be 8.25". I have a 29" (i think) tire height. I think my front tire height is 26-1/4".(i'll double check)
Laying frame.. Your going to have a tough time. The only pic of mine with mine layed out, the truck has 2.5" z, 3" dropspindles, and slam specialties 7 bags with cups (which are thick) My frame barley hit (Pretty much had to bounce it) So... I'm estimating another 1-1/2" with the porterbuilt lowers, so with my about 1" cut out (I did 2x5, stock frame is about 6"-6-3/8" where the awful bend is), mine should lay out still. im hoping.. The frame only hangs 1-1/4" below the pinch as it is. so mine should be about 1/4" off the ground layed out....
Check out how this crossmember is.. Simple to build. I like it. obliviously still bolts in.
http://www.tennesseecustoms.com/foru...hp?f=10&t=3427
Old 07-01-2011, 12:41 PM   #121
Nobaddaze
Nobaddaze's Avatar
ok, that makes sense... my notch is 8" but my tires are 31". i know i cant "lay frame", but im notching so in the future i might be able too. my stock front xmember is going to be my lowest point. im planning on a PB dropmember someday so i want my back to be ready for that day.
id like it if it still rolled when layed out just in case something happens with my air system and i lose pressure. (wont leave me stranded)
My Build
Old 07-01-2011, 04:12 PM   #122
luifer76
luifer76's Avatar
i was gonna ask why not just welded but that answers my question....
Old 07-01-2011, 04:51 PM   #123
Nobaddaze
Nobaddaze's Avatar
Wink Re: Nobaddaze's 82 C10 Cruiser Build
Yea, im regretting the powder already. That wouldve made my c-ntoch, crossmembers, front bags, and all the other bs WAY easier. btu at the time i was just doing a static drop so i figured "why not"
Big mistake
My Build
Old 07-01-2011, 08:08 PM   #124
luifer76
luifer76's Avatar
it looks good so far tho keep up the good work..... by the way since my 73 is not body dropped its just bagged i can let all the air out and still drive it on level roads the only thing i can't do is turn i have to raise it up but i kind of like that just in case some thing happens.....
Old 07-01-2011, 09:22 PM   #125
mooseknuckles
mooseknuckles's Avatar
looks good...but I would paint it all one colour! lol.
mooseknuckles is offline   Reply With Quote
