Old 06-24-2011, 04:02 PM   #1
gotchamel
Power steering belt adjustment?
Putting new belts on my 69 c10{307}and having a tough time getting the old ps belt off.I cannot seem to get adjustment.I backed off what appears to be the right nut.Its mounted on the lower block.Ideas?
gotchamel is offline   Reply With Quote
Old 06-24-2011, 04:06 PM   #2
67chevy1series
67chevy1series's Avatar
Re: Power steering belt adjustment?
when hunched over the driverside fender look at the power steering pump you will see a bolt sticking out that is on a slide kinda like the altenator bracket, once you loosen it it should slide towards the harmonic balancer, and then whalaa!
67chevy1series is offline   Reply With Quote
Old 06-24-2011, 04:22 PM   #3
TheSeeker
If you are going to replace the belt anyway....just cut the damn thing off, then adjust the bracket without the tension on it while fitting the new belt..
TheSeeker is offline   Reply With Quote
Old 06-24-2011, 04:44 PM   #4
gotchamel
Yeah,thats what I was thinking.I just don't like to get whipped by a bracket.
Thanks!
Old 06-24-2011, 05:47 PM   #5
long69
would make sure everything is loose before i go cuttin' only because it would make a nice spare.
long69 is offline   Reply With Quote
Old 06-24-2011, 06:12 PM   #6
gotchamel
You are correct.Thanks.
Old 06-24-2011, 09:25 PM   #7
dmack91
dmack91's Avatar
I had to loosen the lower bolt to get enough travel on the pump to remove/replace the belt. The lower pivot bolt is actually two bolt/studs and you have to loosen both to get enough travel.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 06-24-2011, 09:42 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Don't forget the nut on the backside near the pressure line fitting.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-24-2011, 09:45 PM   #9
MagmaJct
MagmaJct's Avatar
I typically try to avoid cutting or breaking old parts out for a couple reasons:
1) The old part often makes a good emergency spare.
2) If removing something requires breaking it, then how are you going to get the new one installed? If it's possible to remove the old one without breaking it, then the new one will go in.
MagmaJct is offline   Reply With Quote
Old 06-26-2011, 06:58 PM   #10
gotchamel
Got it done,thanks for the info.Created a leak though,found a loose fitting,hopefully thats it.
