Old 06-26-2011, 12:42 AM   #1
KrazyRay
KrazyRay's Avatar
Parting 72 1/2 ton 2wd long bed
Just in is a 72 long bed that has bad sheet metal and the grille and frame horn are bent up. I will be using the bed, but the rest is being sold. Please respond in thread to avoid confusion.
Thanks, Ray
core 350 motor- $150 local SOLD
core th350- $50 local
5 lug front disc brake setup- $150 local
5 lug coil spring rear end complete drum-drum- $300 local SOLD 5 lug steel wheels- $100 plus shipping
alt brackets- $40 shipped SOLD
power steering brackets- $40 shipped SOLD
crank/water pump pulleys- $31 shipped SOLD
power brake booster, mc, prop valve, brackets- $60 plus shipping
rams horn exhaust- $60 pr. plus shipping
gauge cluster (bezel has holes drilled in it)- $25 plus shipping
AT steering column- $60 plus shipping SOLD
grille emblem with cracks- $10 shipped SOLD
radiator support- $80 plus shipping
gas pedal assembly- $40shipped
outside heater box- $40 plus shipping
black visors- $25 plus shipping
bench seat needs cover- $50 local
black seat belts (no center)- $36 shipped SOLD
small block engine stands- $20 shipped
black door panels driver condition- $40 plus shipping
window regulators- $15 each plus shipping
inside door handle guts- $15 plus shipping
black vent windows- $30 pr. plus shipping
AT shift linkage complete column to trans- $30 plus shipping
1 1/16 sway bar with frame brackets- $30 plus shipping
1/2 ton trailing arms- $50 plus shipping
cab patches- $25 and up plus shipping
frame pieces- $25 and up plus shipping
KrazyRay is offline   Reply With Quote
Old 06-26-2011, 12:45 AM   #2
teeitup
Just like to part out trucks!!
teeitup's Avatar
Re: Parting 72 1/2 ton 2wd long bed
Interested in the seat belts Ray, Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 06-26-2011, 12:49 AM   #3
KrazyRay
KrazyRay's Avatar
pics
Old 06-26-2011, 12:54 AM   #4
KrazyRay
KrazyRay's Avatar
more
Old 06-26-2011, 01:04 AM   #5
KrazyRay
KrazyRay's Avatar
Randy, I will pull the belts and get pics.
Thanks, Ray
Old 06-26-2011, 07:01 PM   #6
BigRed76
BigRed76's Avatar
If they glove box insert is still present, then what shape is it in?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-26-2011, 07:13 PM   #7
cjohnson6772
cjohnson6772's Avatar
Interested in the pull handle for the passenger side kick panel vent. All I need is the handle, rod, and knob. I have the door and seal already. Need it shipped to 28678
cjohnson6772 is offline   Reply With Quote
Old 06-26-2011, 08:53 PM   #8
sleepertruck72
sleepertruck72's Avatar
KrazyRay,
How much for dome lamp shipped to 95380 ?
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 06-26-2011, 09:20 PM   #9
ChevyLvr4Life
ChevyLvr4Life's Avatar
Ray, I would like the altenator and power steering brackets to 24078 if they are still available.
Thanks, James
1970 Chevy C10 LWB 307 3OTT 3.73 gear
ChevyLvr4Life is offline   Reply With Quote
Old 06-26-2011, 09:50 PM   #10
mater63
mater63's Avatar
how much for the pan hard bar bracket (tracking bar on driver side frame) to 47274
mater63 is offline   Reply With Quote
Old 06-26-2011, 11:16 PM   #11
KrazyRay
KrazyRay's Avatar
Sorry, I had to run out and get another truck. I will have answers late tonight.
Thanks,
Ray
Old 06-26-2011, 11:17 PM   #12
teeitup
teeitup's Avatar
Thats the fun part Ray, going out and getting them
1980 chevy swb 4x4
Old 06-27-2011, 01:10 AM   #13
KrazyRay
KrazyRay's Avatar
Randy, The female part of the belt is cracked and broken. I can check my parts stash on Wed. to see if I can complete the set for you. Its really fun when you pick up a front end wreck short bed with a cherry bed!
Big Red76, Sorry, the insert is junk.
cjohnson6772, $20 shipped for the kick panel pieces.
sleepertruck72, $16 shipped if it comes out unbroken.
James, $70 shipped total for both bracket sets.
mater63, The bracket is in bad shape. I wouldn't run it on my truck.
Thanks,
Ray
Old 06-27-2011, 08:37 AM   #14
ChevyLvr4Life
Thanks Ray, pm sent
James
Old 06-27-2011, 12:14 PM   #15
cjohnson6772
Ok. I think I know of a truck local that I am going to check. I will get back with you if I wind up needing it.
Old 06-27-2011, 12:39 PM   #16
gcburdic
Restoration Virgin!
gcburdic's Avatar
ray...is that a black auto column? Is it tight? How's the steering wheel? what's shipping to 28031? Thanks
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-27-2011, 01:12 PM   #17
sleepertruck72
Ray,
Sounds good. I'll take it if it stays unbroken.
72 C20 Longbed
05 1500 Z71
Old 06-27-2011, 01:56 PM   #18
KrazyRay
KrazyRay's Avatar
James- pm returned.
cjohnson- no problem.
Geoff- Its a black column, it feels tight. $85 shipped. The wheel is badly cracked.
sleepertruck- I will know Tues.
Thanks,
Ray
Old 06-27-2011, 05:18 PM   #19
botmfedr1
botmfedr1's Avatar
is the fan shroud in good condition? no broken tabs or any issues?
if its G2G, how much and please quote to 79908.
text 253-495-0880,
thanks
botmfedr1 is offline   Reply With Quote
Old 06-28-2011, 01:50 AM   #20
KrazyRay
KrazyRay's Avatar
This fan shroud is junk, however, I have a nice one with no broken tabs for $30 plus $17 shipping to TX.
Thanks,
Ray
Old 06-28-2011, 09:20 AM   #21
botmfedr1
botmfedr1's Avatar
Hey Krazy,
If it's not too much to ask, text me a couple of good pics of that fan shroud.
253-495-0880, I'm needing one soon!!
Thanks!
Mondo
Old 06-28-2011, 02:07 PM   #22
JORGIE95961
hOhows that inner grill, what youwant for it.? also yougot any chevy tailgates?, i dont mind a couple dings for the right price..
JORGIE95961 is offline   Reply With Quote
Old 06-28-2011, 08:50 PM   #23
KrazyRay
KrazyRay's Avatar
sleepertruck- The dome lens came out ok, but the po had screwed the housing to the truck because the mounting tabs were broken. It works and does not show, but it is an imperfection.
Mondo- The shroud in the pics is the same as the ac one in my truck.
JORGIE- The inner is broken at the driver side where it is pushed in. Sorry, no tailgates.
Thanks,
Ray
Old 06-28-2011, 09:22 PM   #24
gcburdic
Restoration Virgin!
gcburdic's Avatar
Ray...waiting to hear from my partner in crime on our 71 project to see if he has one yet or if I should pick this one up....he's visiting his family in a small town in MO so cell signal isn't the greatest
Geoff with a G
Old 06-29-2011, 10:18 AM   #25
JORGIE95961
Thanks,
Ray
still may be interested in the inner if the price is right.. wouldnt be the first time i made one outa two lol
