Old 06-27-2011, 09:26 AM   #51
kieth
kieth's Avatar
Re: Sun Tachometer Retrospective
[quote=markeb01;4756634]That looks great with the upgrades. Those later GMC panels looked so much nicer than the early style mine came with.
Originally Posted by kieth View Post
Here is what it looked like finished on my 66
Thanks Mark, it is of course the stock instrument panel, just upgraded a little.......Like my whole truck I am trying to redo it with a retro theme but better than it was ever done originally........Just a little upgrade.
kieth is offline   Reply With Quote
Old 06-27-2011, 12:59 PM   #52
Joemomma1
Joemomma1's Avatar
I like what you did with yours kieth. I wanted some contrast on mine also so I left the black on the perimter and around the guages.
Joemomma1 is offline   Reply With Quote
Old 06-27-2011, 03:01 PM   #53
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Sun Tachometer Retrospective
Sun FZ88R Tach Tachometer Gasser Hot Rod/Street Rod
$139.28
http://www.buy.com/prod/sun-fz88r-ta...219380994.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-27-2011, 05:53 PM   #54
kieth
kieth's Avatar
I was originally going to do that but the flat surface on mine did not look good it had some deep imperfections, so we tried spraying it with crinkle paint and it covered it up. Necessity is the mother of invention.......
Your looks great........Kieth
ps set my bed on today---needed the room in the paint booth......
http://kieth.smugmug.com/Trucks/66-G...7_QhFTT5D-A-LB
Old 06-28-2011, 12:32 PM   #55
HEI451
I've installed groups of old Sun tachs and never upgraded the electronics, not even to use them on HEI ignition systems, nor do I use batteries in the transmitters.
To power up the transmitters, I go to Radio Shack and get a 12 volt to 12 volt power inverter power supply, one that is designed to take power from a cigarette lighter. I set the voltage need on the main box of the power supply, cut the cigarette lighter plug off, and hard wire the thing in place, and they work just fine, no longer need replacement batteries.
HEI451 is offline   Reply With Quote
Old 06-28-2011, 01:58 PM   #56
markeb01
Senior Enthusiast
markeb01's Avatar
Outstanding tip. Can you post a picture or model number of the type inverter you use for these installations? Thanks for sharing!
Old 06-28-2011, 03:04 PM   #57
kieth
kieth's Avatar
I took the more expensive route and everything was replaced with new electronics for $219.99......oh well live and learn. Kieth
Old 06-28-2011, 04:03 PM   #58
198plus
198plus's Avatar
That is really nice....Almost like mine, except I'd rather have a vacuum gauge instead of the clock.
Originally Posted by LeftCoast32 View Post
Here is my finished Vac and Tac Cluster
198plus is offline   Reply With Quote
Old 06-28-2011, 11:03 PM   #59
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Originally Posted by 198plus View Post
I really like your Clock and Tach Cluster!!!
LeftCoast32 is offline   Reply With Quote
Old 06-28-2011, 11:40 PM   #60
198plus
198plus's Avatar
I like yours better........
Old 07-14-2011, 03:08 PM   #61
chevyrestoguy
chevyrestoguy's Avatar
Leftcoast32-
Where did you score that vacuum gauge? They are not easy to find.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-14-2011, 10:03 PM   #62
HEI451
I wouldn't mind finding either the vacuum guage, and/or the clock. I'd put a different tach under the dash if I had one each of the other guages.
Old 07-14-2011, 10:37 PM   #63
LeftCoast32
Custom Builder
Originally Posted by chevyrestoguy View Post
Leftcoast32-
There is a guy that sells them on e-bay - http://motors.shop.ebay.com/235chevy...id=p4340.l2562
Old 09-02-2011, 05:14 PM   #64
pdxhall
pdxhall's Avatar
Well, I'm always a sucker for old stuff and couldn't resist this buy on craigslist today. I bought this old Sunpro tach. The old guy (older than me ) that I got it from claims it will work with batteries. Okay I know the obsolete battery thing but a conversion or modification is possible. But I'd like to find out more about it. I've seen ones on here that look close to this but none with a black face and it did come this way. I was hoping Markeb01 would know. You seem to be our resident expert. But any help would be great. All the guy said was that is was "real" old. I got it for "real" cheap, I think.
pdxhall is offline   Reply With Quote
Old 09-02-2011, 10:59 PM   #65
markeb01
Senior Enthusiast
markeb01's Avatar
Very cool purchase, I like all the various vintage models. The tach you acquired appears to be a standard 5,000 rpm Sun Tach head with an EB9A transmitter for an 8 cylinder engine running on 12 volts. There should be a tag on the back of the tach head identifying which transmitters are compatible, hopefully they were used together and are a matching set.
I’ve seen black gauge faces and cups sold for automotive use. They were never as popular as the chrome models, but for a fleet vehicle the boss may not have wanted to pay for flashy appearance. I’ve also seen black bezel gauges sold for industrial applications like tractors, and also airplanes, but most I’ve seen use a 2,000 or 3,000 rpm range.
The lack of a zero adjusting screw on the panel below the gauge face probably dates it as before the mid-60’s. The needle and dial face appear to be in great condition. A nice feature of these tachs is the ability to easily remove the mechanism from the bezel/housing. Should you want a chrome bezel and can find one in good condition, simply remove the fasteners on the back and transfer the mechanism to the chrome bezel housing. It’s that simple. It comes out as a complete unit. There is no need to touch the needle or the face.
Having been painted all these years, the bezel may also be an excellent candidate for chroming. Most original and even NOS tachs have wear scratches and pits in the chrome. Chrome plating a painted bezel may produce a result even nicer than NOS.
Also – for those with interest, here’s a bit of Sun Tachometer history I’ve recently discovered (because I wanted to know myself). The original 1950’s–1970’s Sun Tachometers were produced by Sun Electric Corporation located in Chicago, Illinois. In 1988 Sun Electric licensed the rights to produce the Sunpro brand to Actron Manufacturing Company. In 1992 Snap-On Tools acquired Sun Electric for $110 million.
What all this means is that the Sunpro brand came along years after the departure of the classic Sun Gauges from the automotive culture. There really isn’t any connection between the vintage Sun gauges and the current Sunpro retro styled gauges, beyond a lineage of corporate licensing agreements. Here are a couple of related historical links explaining some of the details:
http://www.sunpro.com/timeline.php
http://www.highbeam.com/doc/1P2-4127476.html
Old 09-03-2011, 12:12 AM   #66
pdxhall
pdxhall's Avatar
Thanks for your help. I've been reading all your posts on this so I was hoping you could help. I've looked around on various pages and I haven't seen another exactly like this one. The transmitter is the one that goes with this unit. Would it be best to have it updated for use by Williamson's or someone, or have someone come up with an alternative to the 1.35V battery issue? By the way, I picked it up for $25.
Old 09-03-2011, 12:15 AM   #67
hopped up
hopped up's Avatar
i really want a dash with the temp gage and oil pressure too. anyone have one pm me. i love the tachs too, learning lots if usefull info. great thread!!
hopped up is offline   Reply With Quote
Old 09-03-2011, 12:17 AM   #68
hopped up
hopped up's Avatar
that in dash factory tach is badass!!!
Old 09-03-2011, 12:01 PM   #69
Keith Seymore
Keith Seymore's Avatar
Originally Posted by pdxhall View Post
... or have someone come up with an alternative to the 1.35V battery issue? .
I like to think so; (post #6 from this thread):
Originally Posted by Keith Seymore View Post
You might appreciate this little tidbit:
My car still uses the old battery powered sending unit, mounted underhood -
When I got the car running again back in the mid 90's, naturally the batteries were dead and the tach didn't work. I thought "...where am I going to get those old batteries like that?"
Well, I noticed that they were physically about the same size as a modern "AA" size battery, although the modern battery is 1.5V and these vintage batteries were 1.35V.
I asked one of the electrical engineers at work about it and he said "...I'd just put a couple AAs in a flashlight and run 'em down until they're 1.35V".
That's what I did and it's been working fine ever since.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-03-2011, 12:10 PM   #70
HEI451
I posted the ONLY reasonable alternative to replacing batteries inside the units, have done what I outlined for DECADES, NO ADVERSE ISSUES, but, it seems some just do not accept change that works with electronics.
Once again, REPLACE THE BATTERIES WITH A DC TO DC POWER INVERTER, one that has the capability to make the correct DC volts, and wire it to come on with the ignition switch. Simple, basic, permanent.
Anything else is a hassle, pain in the 6.
Old 09-03-2011, 12:28 PM   #71
Keith Seymore
Really? Sounds like you feel pretty strongly about it.
I probably shouldn't respond, but let me ask this: Why would I add an additional, modern component to my otherwise vintage, period correct and unrestored 4800 mile GTO, when simply replacing the batteries seems to have worked? That's pretty much the limit of my electrical capablility anyway.
Keep in mind this repair was done nearly 20 years ago and still seems to be fine. If it lasts another 20 years I won't be around and my children will have to deal with this issue.
In my mind the best solution is the simplest solution that works.
My $.02.
K
1979-1986
1986 - 2019
Old 09-03-2011, 12:55 PM   #72
HEI451
And, NOBODY is forcing you to come into the 21st century, but, the "best" solution IS to update the system to NOT require any replacement parts any tome in its lifetime, and that IS the DC to DC inverter install. The ones I use fit inside the sender, not seen outside the unit.
Now, I have dead stock vehicles in my collection, and I can say that if you were to look at one of my other vehicles that have had this done, you could not find the conversion to this inverter. Not even judges at concourse events have found them, until I told them, in all fairness.
Don't get so sarcastic about change that works, we have enough "change we have been waiting for" in government, that will never work.
I also have a couple of vintage Pontiac's, along with 119 other vintage cars and trucks. I never advocate butchering up any part of them. If a person doesn't want to make a change, wants it dead stock as it was, I fully support that, but, if someone has the need for better, and their vehicle is not concourse, and they can live with the update, who cares if they install an inverter, vs the batteries, go for it. Let the concourse and other people do as they wish, it is all open to the OWNER, not the rest of us.
End of all this, I am sick and tired of being forced to defend EVERY post I make, that someone else doesn't agree with, for whatever reason.
Old 09-03-2011, 01:30 PM   #73
LeftCoast32
Custom Builder
Here is a little better picture of my Gauge Package. You can see my Sun Tachometer Transmitter behind it. The transmitter has been modified so no batteries are needed. You can not tell this has been done and it works the same. I did this because I didn't want the hassle of changing the batteries all the time. My truck isn't a concourse restoration so no big deal to me. Like stated unless they want to dismount it and take it apart they wont know anyway.
Old 09-03-2011, 02:07 PM   #74
Keith Seymore
Excellent! Since we are in agreement, I will leave my car as is, and continue to dwell in the early 1960s, where I am most comfortable, both mechanically and politically.
K
1979-1986
1986 - 2019
Old 09-03-2011, 02:11 PM   #75
markeb01
Senior Enthusiast
markeb01's Avatar
Please share with us what inverter you are using. I’ve looked on Radio Shack and don’t find what you are describing.
