07-05-2011, 10:46 AM | #1 |
how to hold up motor when change tranny?
I have to re an re a tranny in a feild and was looking for a good save way to hold up the engine,not do crazy on putting blocks under the oil pan.I have No cherry picker either
07-05-2011, 10:55 AM | #2 |
Slots go on anything!
Re: how to hold up motor when change tranny?
You can wedge a 2x4 between a head and the forewall, or support the pan with wood and a jack. I would remove theistrubutor cap either way, just to be safe. The engine is only going to rotate so far before binding on the engine mounts (usually just enough to shatter the cap).
1974 Jimmy- 5.3/4L80e/NP241 |
07-05-2011, 11:37 AM | #3 |
Newbee
I have ran a tie down strap under the pan, to each frame rails before. Usually if the motor mounts are good, I just let it sit there.
07-05-2011, 12:50 PM | #4 |
You can set the pan on a piece of wood, then use an axle jack under the wood. I did that for years before I could afford a cherry picker.
07-05-2011, 02:30 PM | #5 |
I just thought was alot of weight on the pan ,tranny and motor
07-05-2011, 02:48 PM | #6 |
it'll be fine, pull the dizzy cap loose and snatch it out.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
