Old 07-05-2011, 08:37 PM   #1
Mrtn15
Mrtn15's Avatar
Some lights in gauge cluster don't work
okay, well.. The only lights that work in my Gauge cluster are... ( Blinkers, Fasten belts, Brake, And the few white lights that light up the gas gauge, ect. now.. Are there lights that illuminate when your headlights come on ? or anything else like that. ? I really have no accessory lights other than my blinkers.
I hate having to flick my light switch to see whether i'm on my brights or not.
And my gauge lights were so dim (even when I turn the switch all the way up) that I had to install blue l.e.d's that I bought from Auto Zone.
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 07-05-2011, 08:42 PM   #2
J Knight
J Knight's Avatar
Re: Some lights in gauge cluster don't work
I posted what to do on the need help again thread.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-05-2011, 08:47 PM   #3
Mrtn15
Mrtn15's Avatar
I couldn't figure out how to delete this thread!
Old 07-05-2011, 08:56 PM   #4
J Knight
J Knight's Avatar
Thats a typical problem. I know you are young and have a lot of energy but exercise a little patience with this one. Like i said in the other thread carefully remove the gauge bezel, then very carefully remove the gauge cluster, there is only one maybe two plugs in the back of it and a speedometer cable. once you get it out you will see the little black light sockets, just twist them all out and replace bulbs and carefully put it all back together. Did i mention to be patient and carefull.
John
Old 07-05-2011, 09:05 PM   #5
Mrtn15
Mrtn15's Avatar
okay, i'm guessing It's easy to mess up the printed circuit ? and I'm only 19 haha in college for criminal justice & Automotive TECH !
And Good, I was wondering how to change the speedo cable, now I know. Thanks!
Old 07-05-2011, 09:10 PM   #6
J Knight
J Knight's Avatar
This fix is easy just go slow and dont force anything becauce its all plastic.
John
Old 07-05-2011, 09:15 PM   #7
Mrtn15
Mrtn15's Avatar
okay! Thanks man! I'm going to try and get the lights on thursday!
If you ever need help, let me know haha.. I will help if I can!
Old 07-05-2011, 09:19 PM   #8
Mrtn15
Mrtn15's Avatar
While im still on.. Is it hard to take out the overload springs on my truck ? or would you ever even do that ? I want to lower the back end of my truck, that way its even with the front
Old 07-05-2011, 09:32 PM   #9
bradford
Not the best idea but its not hard. jack the truck up on the frame just a few inches, get 2 sets of C-clamps and clamp the leafs together. Loosen the U- bolts and jack it up til its off the axle.
Remove center pin, ditch the overload spring and replace the center pin with a shorter one.
Lower it back to the axle, replace the U-bolts. done
Dont lift it too high off the axle. Just a little bit. Brake lines and diff breather hoses are still attached and can be broken if stretched.
Now, back to the speedo cable.
When you start to take the bezel out, you will notice you cant go very far. Thats the speedo cable holding it in.
There is a metal clip thing that you pull or lift back on as far as you can. Grasp the cable end and push it towards the bezel and then pull it off. So, lift clip, push back and pull cable out.
That will give you enough room to get to the bulbs.
Just be careful. Its 20 something year old plastic
bradford is offline   Reply With Quote
Old 07-05-2011, 09:34 PM   #10
Mrtn15
Mrtn15's Avatar
okay! Sounds simple enough ? and why isnt removing the overload a good idea ? would it drop it more than i needed ?
Old 07-05-2011, 09:44 PM   #11
bradford
it may drop it lower simply because your springs are kinda old and it may sag. I did this to my Nissan Titan and it made it about 1" lower in the rear. The other reason is you wont be able to put much of anything in the bed before maxing it out.
Old 07-05-2011, 10:03 PM   #12
Mrtn15
Mrtn15's Avatar
ohhhh! I think i will keep them in there!
Old 07-05-2011, 10:07 PM   #13
J Knight
J Knight's Avatar
It would be better to buy a kit for the drop you want if you are not sure how to manipulate the springs.
John
Old 07-05-2011, 10:14 PM   #14
bradford
After I did that, I purchased some lowering shackles.
cheap
help please, j knight
