Old 07-06-2011, 06:37 PM   #1
hbchevy
hbchevy's Avatar
Crossmember identification and question?
Hey guys I have been trying to find something on here about the crossmembers being almost universal in that on some trucks the crossmember was the same wether it was leafs or trailing arms. Is this correct?? Thanks in advance.
Here is a pic of mine
hbchevy is offline   Reply With Quote
Old 07-06-2011, 07:32 PM   #2
hbchevy
hbchevy's Avatar
Re: Crossmember identification and question?
Forgot to mention its a 1970 lwb c10... thanks.
Old 07-06-2011, 08:36 PM   #3
JimKshortstep4x4
It looks like you are referring to the crossmember that is in the middle and it would react the trailing arms on a truck that has coil springs. From what I have seen the cross members are the same on the 2 wd whether coil or leaf springs. My son's original 69 GMC with leaf springs had the crossmember on it with the trailing arm brackets riveted to it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-06-2011, 11:52 PM   #4
hbchevy
hbchevy's Avatar
Ok cause that's what im trying to figure out ...if with this crossmember I can convert to the trailing arms by installing the arm mounts and cutting the spring pads off and getting it mocked up and welded it in and install adjustable trac bar?
