#101 | |||
But Found Her 25yrs Later!
Re: My 66 Service Truck Build Thread
Right now during the dryer summer months, I want to get my cab patched up and protected.
I'd also like to at least do a quick spray on the box just to get it looking a smidgen better. It's pretty chipped up, and the black is brushed on. I don't want to bother doing a lot of sanding, so I'll do a quick over and then do this as Mark talked about here: Quote:
#102 |
The 60-66 GMC/Pontiac guy....
Yeah, I need to rush out there and get busy myself. Was only 105 in the shade today, a sure sign the hot weather is on it's way...
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac
#103 |
Great thread for future reference when i go to do the brakes:
http://67-72chevytrucks.com/vboard/s...d.php?t=460791 Another thread for future reference: http://67-72chevytrucks.com/vboard/s...248460&page=93
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 07-08-2011 at 04:34 PM. |
#104 | |
However, I can't help you with your issue re: 66 vs 65 but it sure made me laugh.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#105 |
Yes, I try not to start a new thread asking questions that can be answered with just a little searching.
#106 |
Found me a beautiful straight clean box for $100
![]() The catch is I had to unbolt it from the f rdHe just wanted it gone. I was fine with that. ![]() Now I won't have to try and restore my old beat-up box.
#107 |
love the service box very cool!
Car & Truck Projects Google Community. https://plus.google.com/communities/...80679980403145 Youtube channel. http://www.youtube.com/channel/UC2HB...view_as=public 1964 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=419525 |
#108 |
60-66 Nut
Wow, that looks good. If it is as nice as it looks in the pic, you stole that box.
#109 | |
Did you get vaccinated afterward... Seriously, you should see a Doctor and make sure you didn't catch anything.. Gotta go.. need to wash my hands after typing the F word...
#110 |
These guys took my 79 donor away.
I wish I would of got a pic as they still had it hanging from their claws way up in the air. ![]() ![]() Posted via Mobile Device
#111 |
![]() Join Date: Mar 2011
I get that same soreness and tire easily when working on my 66. Since that makes 2 of us it must be the 66 trucks. LOL
#112 | |
#113 |
Got the old box off today.
I cut each side off and will be keeping them for tool cabinets.
#114 |
I always like how these trucks look even without a bed.
That isn't rust on the back of the cab, that's the original county orange. ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 07-16-2011 at 02:30 AM. |
#115 |
My Cab Corners arrived today from Dan's here in Portland.
They sent me two different brands. TriPlus for the Driver's side and I don't know for the Passenger's. I will be exchanging the passanger's side for a Tri-Plus brand. The off brand is just way too cheaply made. The metal is terribly obviously thinner. ![]() The shape of the body lines are very under shaped. The TriPlus is far superior. ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 07-19-2011 at 03:24 PM. |
#116 |
Pressure washed the frame rear section.
I'll be doing the rear gas tank upgrade and cab corners while I have the box off. ![]()
#117 |
What kind of tank are you planning to use? Just wondering because I'm at about that stage on my 66. The plan right now is to use a 64-66 mustank tank. I've seen a couple used in our trucks and they are almost a drop in and very little hangs below the frame. They are only 16 gal., though, and also the sender needs to be modified to 0-90 ohms.
#118 |
I have two tanks to choose from.
My first choice will be a huge 79 suburban tank I got off my donor - similar to the blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=474448 If I don't like how it's coming together, I got one off of the F250 that I got the service box off of. It's looks to be about half the depth of the suburban tank. I'll try and load some pics of the tanks this afternoon.
#119 | |
I need a tank bad. I hate it in the cab.. makes me real fricking nervous!
#120 |
Here's the F
rd F250 gas tank.I see now it won't fit between the rails. If I have to go below the rails, I might as well use the huge suburban tank because it fits between the rails, so I'm guessing it won't hang any lower than the f rd tank mounted below the rails.![]() ![]() 79 Suburban tank: ![]()
#121 |
66-PMD. you're right. my bad, it is 30 ohm.
#122 |
66-PDM...you're right, my bad, it is 30 ohm.
#123 |
65=30ohms, 66=90 ohms is how i believe is how it goes
ron |
#124 |
I found two clean doors. Driver's and
Passenger's. $325 for both. After driving around looking at rusty bottom doors, I figured I had better get both of these. I'll get some pics up later. I'm tempted to buy the hood also. I posted in the parts forum asking what it might be worth. Posted via Mobile Device
#125 | |
Saved for future reference:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
