Old 07-08-2011, 02:36 PM   #1
gotchamel
Lifting truck?
Any ideas on lifting a truck more than a jack and stands would do for easier access to treat and paint surface rust on the frame and underside?I don't have the use of a vehicle lift.Thanks.
gotchamel is offline   Reply With Quote
Old 07-08-2011, 02:38 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Lifting truck?
Safest way is buying a bigger jack and bigger jack stands...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 07-08-2011, 02:38 PM   #3
dubds10
Stalker Nate
Re: Lifting truck?
Could always drive it up on the wheel stands like most do for oil changes. That'd give you an extra foot or so higher and not have any jack stands in your way. Guess it depends on if your truck is low, stock or lifted right now to how much height you can get.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 07-08-2011, 02:42 PM   #4
gotchamel
Re: Lifting truck?
Stock height,higher the better as long as its safe.Anybody ever lifted one with a crane?
Old 07-08-2011, 03:03 PM   #5
Beat68CST
Beat68CST's Avatar
Re: Lifting truck?
put the jack stands on blocks, I do that all the time.
Beat68CST is offline   Reply With Quote
Old 07-08-2011, 03:21 PM   #6
hayhauler71
hayhauler71's Avatar
Re: Lifting truck?
with six ton stands i can sit under mine
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-09-2011, 05:34 PM   #7
gotchamel
Re: Lifting truck?
Do you get to that height in one shot?Or do you jack it,block it and jack it some more?Just want to be safe.Thanks.
Old 07-10-2011, 12:29 AM   #8
hayhauler71
Re: Lifting truck?
I use a piece of 4x6 lumber on my jack pad under the front cross member [near the oil pan] as high as I can go and install the stands on the frame. Then I jack on the rear diff [without block of wood] as high as the jack will go and put the stands on the rear axle hope this helps you out
Fuzzy
