Old 07-09-2011, 10:34 PM   #1
mikie 1954
Red face Brake controller
Has anyone istalled a brake controller in one of our trucks? If so what kind did you use & how do you like it? I have a 64 GMC 3/4 ton and want to use it for my trailers at times but I know it needs a controller, just not witch one works in this year of truck. THANKS MIKE
mikie 1954 is offline   Reply With Quote
Old 07-10-2011, 02:00 AM   #2
Woogeroo
Re: Brake controller
electric trailer brake box that used to be on my truck
That box was on my truck when I bought it. I left it on there until it started leaking brake fluid on my foot. It had an actual brake line that ran inside to the box, which, from what I have read was used to determine the amount of pressure to determine the signal to send down the wires to the rear.
It wasn't fixable as far as I know, so I removed it.
I never towed with it, but the fella I bought the truck from was using it to tow their boat to the lake as I recall.
I suppose what you need to consider is what you are towing, what brake master cylinder you are using, etc..
-W
Woogeroo is offline   Reply With Quote
Old 07-10-2011, 08:10 AM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
An electric controller can be installed on anything with a brake light circuit. So yes, it can be done.
Best advise is to use a 30amp self resetting circuit breaker on the positive lead.
You also have to watch the color scheme of the wiring too. If I remember, black is hot and white is ground. Blue is the the trailer brake and red is for the brake light circuit.
If you need more help with that PM me.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-10-2011, 09:58 PM   #4
mikie 1954
So any of the newer controllers can be used? I did not know if they are for electronic controlled truck or not. Back when I was in high school and just after you had to tap into the brake line, now all the newer trucks I have messed with are pre wired.THANKS 61 FL APACHE for the offer, may take you up in the future. MIKE
Old 07-11-2011, 07:16 AM   #5
61_FL_Apache
Who Me?
Tapping into a hard brake line is a thing of the past. The new ones use a pendulum<sp> to control the braking power and how much to apply.
Here is a link to the one I used last with a Chevy Astro and travel trailer. It works great.
http://www.etrailer.com/Brake-Contro...sha/90185.html
The main thing is watching how it is wired up. You have to think trailer wiring not car wiring.
Steve
2001 Blazer 4D 2WD
Old 07-11-2011, 09:00 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I used to install these all day long in a previous lifetime ....
Another thing when installing a truck plug (if you haven't already) would be a 'charge wire' as well. Trailers with electric brakes also have an onboard 'break-away' battery used to activate brakes in case of accidental uncoupling of truck/trailer. This circuit will keep it charged. Also, if your towing and RV, it'll keep your battery(s) charged as well ....
Wire colors:
LT/Brake = Yellow
RT/Brake = Green
Ground = White
Black = Tail/marker
BLue = Trailer Brake Feed
Red = 12V/Charge wire
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-11-2011, 09:28 AM   #7
61_FL_Apache
Who Me?
This is the wiring diagram from a brake controller I was referring too.
Steve
2001 Blazer 4D 2WD
Old 07-11-2011, 10:56 AM   #8
MikeN
MikeN's Avatar
I installed a Prodigy brake controller in my 64 C10. Easy to install/wire and works great.
MikeN is offline   Reply With Quote
Old 07-11-2011, 04:18 PM   #9
mikie 1954
THANKS. sounds like it should not be that hard to do. MIKE
