Old 07-10-2011, 12:56 PM   #1
Gene Sharp
sway bar
I have a 58 swb 2 wheel drive on a stock frame stock front suspension
v -8
What is a good sway bar to use or would one help
It is a driver
just want it to handle well
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 07-12-2011, 12:18 PM   #2
nikwho
nikwho's Avatar
Re: sway bar
Welder series. You can fab you own up. I'm using one of these on the rear of my '59. Up front I have a '79 Camaro sub frame and I am using the factory sway bar. I may step up to an after market one soon.
http://www.welderseries.com/blog/onl...way-bar-parts/
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 07-12-2011, 10:21 PM   #3
tmoble
Re: sway bar
you mean an anti-sway bar that limits side-to-side movement of the frame/truck over the axle? Or an anti-roll bar that limits the amount of body tilt or lean in corners? These are very different things, sway bar usually on the back, anti-roll bar on the front. usually.
curious, stock trucks usually don't have problems in either of these areas. What kind of shape are you spring mounts and shackles in?
tmoble is offline   Reply With Quote
Old 07-12-2011, 11:48 PM   #4
Gene Sharp
Re: sway bar
Have always called both "sway bars"
I mean the front one
just thinking of making it handle little better while I am rebuilding it
all will get newbushings etc
after all is getting lots more power
Gene Sharp
