Old 07-11-2011, 12:33 AM   #1
losthope
losthope's Avatar
School me on power steering please???
ok so my new rig came with the power steering gear box and bracket mounted on the frame the p/o said i could pull the bracket and pump(i think thats what its called) off a 73 sbc350 motor at a pick-n-pull? is this correct ? ive never messed with power steering before, could anybody tell me where to get or what i need to make it work, what parts and where i could buy them or what years i can pull it off of..pics would help on mounting on motor as well...thanks
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 07-11-2011, 01:39 AM   #2
Captainfab
60-66 Nut
Re: School me on power steering please???
What pump and brackets will be determined by what style of water pump you are running on the engine....short or long. Also it is helpful to know what style of fittings the steering box has. The '69-'70/'80 boxes had SAE inverted flare fittings. From '80/'81-'87 they used a metric size with an O-ring. That makes fitting hoses easier if you have the pump and box with the same style of fittings.
Old 07-11-2011, 01:59 AM   #3
losthope
losthope's Avatar
thanks ,
ill try and find that stuff out tomorrow and take a picture of what i have.
Timmy D.
Old 08-02-2011, 03:19 PM   #4
losthope
losthope's Avatar
ok captain i finally got around to looking at what im working with,sorry it took so long ive been busy getting my other ride on the road....i believe when i replaced the water pump awhile back i used the long style(see pic). i tryed my best to use a flashlight to show you the steering box and where the hose's mount hope the pics are ok i used my cell phone....
Timmy D.
Old 08-03-2011, 12:02 AM   #5
Captainfab
60-66 Nut
Your engine has the long water pump and your steering box is an early one with the inverted flare style fittings.
Old 08-03-2011, 03:57 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
x2 on what the Captain said.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-06-2011, 12:40 PM   #7
wildearp
wildearp's Avatar
Here is CaptainFabs bracket right after I installed it.
I wish other manufacturers had such good instructions and parts that fit this well!
wildearp is offline   Reply With Quote
Old 08-07-2011, 12:46 AM   #8
Captainfab
60-66 Nut
Thanks for the compliment
Your installation looks good!
Old 08-07-2011, 03:45 AM   #9
losthope
losthope's Avatar
thanks captain for the info on the lines! do you have any suggestions on the right brackets and pump i should be running? i see there is other power steering threads but start getting mixed up on what to actually use after looking and reading all of them......just wondering if you know exactly what i should run with the long water pump and flare style gear box?
Timmy D.
Old 08-08-2011, 01:23 AM   #10
Captainfab
60-66 Nut
You will want a pump, brackets and lines from a '73-'79 pickup with a small block. There are a couple of variations with the long pumps. Mainly whether or not the PS pump boss on the water pump is threaded or a smooth bore. If you get a setup and have issues, post up and we can guide you thru it.
Old 08-08-2011, 01:55 AM   #11
losthope
losthope's Avatar
right on captain! your the man thanks for all the help i appreciate it very much..as soon as i get the parts ill post pics and see if i got the right stuff...
Timmy D.
Old 09-12-2011, 01:01 AM   #12
losthope
losthope's Avatar
hey captain f.
i have found everything i need ,thank you very much for the help...i have it mocked up just need a longer bolt and to make a spacer for the top powersteering bracket that bolts to exhaust manifold, since im running headers....will post up a pic when i get it all hooked up for anyone interested... thanks again capt f.
Timmy D.
