07-11-2011, 12:52 PM | #1 |
Missing something for my porterbuilt setup??
So I already have the crossmember and trailing arms from nate. I'm wondering what keeps the rear end from spinning, I'm guessing the u bolts don't exactly accomplish that. I also have a panhard bar from qar and will be running bags over axle. I believe I need more than just shocks to complete my setup. Help please! Thanks
Posted via Mobile Device |
07-11-2011, 02:32 PM | #2 | |
Re: Missing something for my porterbuilt setup??
Sounds like shocks are all that's left.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-12-2011, 12:43 AM | #3 |
so no perches or anything? just arm directly to axle tube correct?
08-12-2011, 09:07 AM | #4 |
08-12-2011, 11:17 AM | #5 |
Registered Cruiser
Your axle should have perches... If not, you'll need to weld them on! If it's for the truck in your avatar, you most likely have a leaf spring set up. If your switching to the trailing arms, you will need to mount the correct perches under the axle for the TA's to properly mount. UNLESS... Nate designed it to be used with the factory perches on a leaf spring set up!
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
08-12-2011, 11:20 AM | #6 |
There should be a mounting pad welded to the bottom side of the axle tube that the trailing arms bolt up against. If you don't have any, get in touch and I can get you a set!
Nate
11-18-2011, 11:37 AM | #7 |
Hey sorry about the late reply. But the truck im dropping is a 68 gmc. And the rear end is a from a late 70s early 80s c10. So if the my rear end didnt originaly use trailing arms do i hafta do some mods?
11-18-2011, 11:46 AM | #8 | |
Nate
11-18-2011, 12:04 PM | #9 | |
Its actually a 12 bolt with leafs. Guessing in might be more mid 70s if that sounds right. And were might i be able to find mounting pads for trailing arms? |
11-18-2011, 12:06 PM | #10 | |
nathan@porterbuiltstreetrods.com Nate
