Old 07-12-2011, 10:24 PM   #1
bobber80
Laying frame exhaust help....
Hay guys Im needing some help from all you guys with realy low trucks I got a 62 swb with Air ride when aired out Im about 2" off the ground is there a good way to run the exhoust maybe outside the frame rails????
Thanks for all your guys help
bobber80 is offline   Reply With Quote
Old 07-13-2011, 12:09 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Laying frame exhaust help....
couple ideas..
fender well headers
just route the exhaust through the fender well and then behind the rocker...
seems like you should be able to punch a hole in the frame rail, and run the exhaust through there, I would box and plate the section w/ the hole though...
Old 07-13-2011, 10:33 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
I run a set of swept back shorty headers and positioned my collector transition just under the front frame kick up, so that I could route my 3-inch exhaust to the outside of the frame. This way I could run the entire exhaust above the bottom of the frame...I had similar concerns as you about clearance.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-13-2011, 01:27 PM   #4
shortbed70
shortbed70's Avatar
I was going to run shorty headers then turn out behind control arms but I ended up going with full length headers and through the crossmember then out the side of the frame.. My front crossmember is about that low but the back limits me with the stock floor.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-18-2011, 12:37 AM   #5
bobber80
Thanks guys I new you guys would have some info......
Old 07-18-2011, 12:41 AM   #6
nachodog2
Hell yeah!!!
nachodog2's Avatar
Any competent muffler shop should be able to route it anyway you want.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 09-23-2011, 08:12 PM   #7
biohazardbill
Do you have a part number for those headers? What motor are you running?
biohazardbill is offline   Reply With Quote
Old 09-23-2011, 09:04 PM   #8
Envy
Envy's Avatar
you guys have it easy. I have to figure out how to route 4" diesel exhaust down the passenger side, and dump it as far away from the cab as possible.
Envy is offline   Reply With Quote
Old 09-24-2011, 02:12 AM   #9
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
What are you building and where in Orlando are you????
MOTOIMPAIRED is offline   Reply With Quote
Old 09-24-2011, 08:15 AM   #10
Envy
Envy's Avatar
A 65 swb on bags with a 12v cummins. I'm in east Orlando. But I'm building the truck at my dad's shop in winterhaven.
Old 09-24-2011, 10:58 AM   #11
vin63
vin63's Avatar
I'm running a Pontiac...they are the Hedman Husslers for the D-port heads.
I've done a couple ISB conversions and routing the downpipe from the turbine is not too bad since it is on the passenger side of the block. One we did as a stack through the bed and the other was routed on the outside of the frame rail, exiting in front of the passenger rear tire. The Cummins exhaust is a lot simpler than the PS and Duramax conversions.
