Old 08-03-2003, 01:44 PM   #1
brad20653
Trans cooler help
Im about to buy a 68 swb he said i drive it home though because the trans cooler lines wasnt hooked up. Does this sound right ? Does it need it ? My 72 doesnt have it .
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 08-03-2003, 01:49 PM   #2
jef5150
Inline 69
jef5150's Avatar
i bet his is an automatic,,,,,yours is probably a 3-4 speed,,,,automatics have tran lines that run into the radiator
jef5150 is offline   Reply With Quote
Old 08-03-2003, 01:50 PM   #3
brad20653
mines auto 3 speed but he does sound right ?
Old 08-03-2003, 01:58 PM   #4
jef5150
Inline 69
jef5150's Avatar
well,im kinda confused,,,,go look at your radiator,,you should have 2 lines going into the side or the bottom {not sure} of your radiator,thats the tranny cooler tank, its part of your radiator,,,,,,,,,if there not hooked up,ya youll blow tranny fluid all over th place.....you might have an external cooler,itll look like a small radiator,,in front of big radiator
Old 08-03-2003, 02:45 PM   #5
brad20653
Where do i mount it in front of the radiator ? How does it keep it cool ? Would it be better to run to the radiator ? or get external
Old 08-03-2003, 03:07 PM   #6
jef5150
Inline 69
jef5150's Avatar
your rambling,,,,,your initial question was that the truck you want to buy & drive home doesnt have the transmission lines hooked up!!!,if the transmission lines on "HIS" truck "ARE NOT" hooked up,,,,,NO, you cant drive it ,youll squirt fluid all over the place,
Old 08-03-2003, 03:15 PM   #7
brad20653
Ok that answered that now i need to know Where do i mount it in front of the radiator ? How does it keep it cool ? Would it be better to run to the radiator ? or get external
Old 08-03-2003, 03:22 PM   #8
jef5150
Inline 69
jef5150's Avatar
an after market tranny cooler would be better, being that only tranny fluid would be running through it,unlike a factory tranny cooler that is incorporated INSIDE your radiator in a seperate tank,,,,,,,,you can mount it anywhere in the front of the truck that you can get air thru it,,,,,try not to block the radiator..jeff
Old 08-03-2003, 03:47 PM   #9
jef5150
Inline 69
jef5150's Avatar
heres a pic
the coolers are roughly 1/4 the size of a radiator theres plenty of room in between the front grill and radiator to mount it.....
Old 08-03-2003, 03:48 PM   #10
brad20653
thanks for all your help
Old 08-03-2003, 04:41 PM   #11
ckenwright
ckenwright's Avatar
I have used the B&M tranny cooler on previous vehicles and they work much better than the stock cooler. I plan to use it on my current 69 when I put in my 350 auto.
ckenwright is offline   Reply With Quote
