Old 07-15-2011, 11:21 AM   #1
66farmer
66farmer's Avatar
Exhaust tip through fender
I have a 66 step side I want the exhaust tip to exit through the rear fenders I'm looking to do a very clean job maybe a trim ring around the hole. So I'm asking if anyone has any ideas on tips, trim rings or anything that would help. I have not seen any step side trucks done this way. The picture shows where I would like it to exit.
(I need some pictures)
66farmer is offline   Reply With Quote
Old 07-15-2011, 11:56 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Exhaust tip through fender
I'm not through the fender, instead through the step
If you want to cut a good hole, I'd recommend getting a threaded hole punch from harbor freight or similar. It shears the metal almost perfectly and they come in a variety of sizes. Plus it doesn't heat up the metal, or warp since its supported. They are pretty inexpensive as well. Import places sell stick on trim rings, but they are pretty ugly.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-15-2011, 11:58 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Here is a thread: http://67-72chevytrucks.com/vboard/s...d.php?t=377873
I'm not a big fan of the exhaust through a panel for a street car/hot rod. Unless you install a wide flange for the opening, you run the risk of damaging your paint.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-15-2011, 12:04 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I like that style.
I had this on my 65.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-15-2011, 12:05 PM   #5
61_FL_Apache
Who Me?
Do you have this on both sides?
Steve
2001 Blazer 4D 2WD
Old 07-15-2011, 03:32 PM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Exhaust tip through fender
http://67-72chevytrucks.com/vboard/s...d.php?t=402277
Rear Fender Exhaust route:
http://www.completecustomsinc.com/cu...p-side-pickup/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-15-2011, 03:46 PM   #7
1Bad62Pro/Street
Stacey Davids GearZ or Trucks had an episode on this.
It was sweet looking.
Old 07-15-2011, 07:27 PM   #8
66farmer
66farmer's Avatar
Mr City That exit point would be to close to the cab for me
Vin 63
Thanks for the link
Mr Apacke
I think I will keep that look for my tractor
Mr Street
Thanks for the picture. I want a more finished look
Old 07-16-2011, 02:45 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ya. My exhaust runs out side the frame, then kicks up a bit to exit out of the step area on both sides.
Old 08-05-2011, 09:40 PM   #10
abigaillozano
Pardon my ignorance, but why did you put this through the step? Is it due to the nature of the undercarriage that you cannot pass this through the fender? Wouldn't it be harder to go up and down from your truck? The tips look nice though, are they stainless exhaust tips?
abigaillozano is offline   Reply With Quote
Old 08-05-2011, 11:21 PM   #11
Slow Build
Slow Build's Avatar
I like the idea of going out the rear of the fender like you are planning. I think it would be more quiet in the cab and the exhaust won't dirty up your wheels.
But here is another option for the step exhaust exit that I thought looked pretty cool (but I wouldn't want to be barefoot on the step).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-22-2012, 06:47 PM   #12
1Bad62Pro/Street
Arrow Re: Exhaust tip through fender
An idea....
Inserted in rear fender or above step plate.
2004 Mustang GT-R Concept Exhaust Tip shown below.
From the web.
Stacey David did this on a truck when he was on Trucks, but I can not find any pictures or videos of this.
Old 06-22-2012, 07:26 PM   #13
63burban4x4
63burban4x4's Avatar
Corvette trim rings?
63burban4x4 is offline   Reply With Quote
Old 06-22-2012, 08:41 PM   #14
1Bad62Pro/Street
There is a company that sells through-the body exhaust tips. These certain type through the body exhaust tips are only available from Stylin' Trucks. Perfect for roll pans or straight through fender or your bed.
The through-the-body exhaust tips require a little cutting to install, but the results are worth it according to them.
http://www.stylintrucks.com/articles...hevytahoe.aspx
http://www.stylintrucks.com/articles...hausttips.aspx
Also:
http://67-72chevytrucks.com/vboard/s...d.php?t=207137
Old 06-22-2012, 11:10 PM   #15
198plus
198plus's Avatar
Also:
I called them a year ago and was told, these tips are no longer available.
198plus is offline   Reply With Quote
Old 06-22-2012, 11:15 PM   #16
1Bad62Pro/Street
Dang.... I guess they didn't sell enough. They are kinda cool.
Old 06-22-2012, 11:30 PM   #17
198plus
198plus's Avatar
I like them, they look killer coming out of bed in front side of tire.........
Old 06-30-2012, 02:17 PM   #18
1enick72
1enick72's Avatar
Here is an option that might work on the step. This is a 53 but similar.
65 short step
edited by staff
1enick72 is offline   Reply With Quote
Old 06-30-2012, 08:48 PM   #19
FreakyMalo
FreakyMalo's Avatar
If they were big enough, '56 Buick portholes would finish it off nicely. You might be able to make something that looks similar out of tubing that's larger than your exhaust tip. Sort of like a frenched antenna?
Reverse light trim rings would work if you were going straight out the back. I did that on my '60 Olds when I ran the exhaust through the bumper.
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 06-30-2012, 09:16 PM   #20
63burban4x4
here's the corvette ones
Old 07-01-2012, 12:05 AM   #21
Mechanic77
Also:
You might still be able to get something similar.....just look for boat exhaust tips, just be prepared.....they are crazy expensive
Check these out....
http://www.corsaperf.com/media/pdf/S...xit%20Tips.pdf
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 07-01-2012, 12:16 AM   #22
198plus
198plus's Avatar
Check these out....
Yea you can buy them tru Donzi, I think they where like way way way up there...........
Old 08-18-2012, 04:46 AM   #23
1Bad62Pro/Street
Last edited by 1Bad62Pro/Street; 10-27-2012 at 04:21 AM. Reason: http://www.youtube.com/watch?v=SwMO-qP1MzE
Old 10-26-2012, 07:43 PM   #24
1Bad62Pro/Street
I always liked the front exhaust fender exit look. Especially with the SS Header Fender Exit Trim Rings!.
You could shoe horn a muffler in there some where
FENDER EXIT HEADERS PIC PLEASE
http://www.yellowbullet.com/forum/sh....php?p=7627043
East Coast Door Warz Pro Mods, Outlaw 10.5, Outlaw Drag Radial, - YouTube
Old 10-26-2012, 08:10 PM   #25
1963c-10
1963c-10's Avatar
very nice........drooling
1964 Short bed trailer
