Old 07-17-2011, 11:18 AM   #26
dragginmetal
here, just not logged in
dragginmetal's Avatar
Re: Air fittings won't screw down
*UPDATE*....
OK heres where i'm at. Sent the tank back. They said nothing was wrong with it, and shipped it back (although it looks like they ran a tap in it, and now the fittings actually screw down abought 3/4 of the way). Now i cant get 2 fittings to seal.
Name:  DSCN1349 (640x480).jpg
Name:  DSCN1347 (640x480).jpg
I have tried 1,2, and 3 wraps of teflon. Also tried tightening it from finger tight to using a wrench for leverage and all in between.
Name:  DSCN1351 (640x480).jpg
Tried different fittings as well.
Any ideas? Y'all still think i should try tapping it? At this point i have well over a $100.00 bucks into this tank already. I'm looking at 2 options.
(1.) cut my losses, buy another tank
(2.) order tap online (no one has one locally) and try tapping it myself
dragginmetal is offline   Reply With Quote
Old 07-17-2011, 11:38 AM   #27
fixit-p
fixit-p's Avatar
Originally Posted by fixit-p View Post
If you were to take a pipe tap to it you may end up with interrupted threads and it will possibly leak.
I was concerned taking a pipe tap to M20-1.5 would leak, can you post up a pic of the threads they chased? If that's what they did then that is just poor customer service.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-17-2011, 12:16 PM   #28
kev2809
low n' slo
kev2809's Avatar
wow..that some sh|tty customer service if you ask me...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-17-2011, 12:47 PM   #29
tubbedII
needs more $$$
tubbedII's Avatar
I'd try 2 things:
1. Get some loctite 474 or which ever one is designed for hyrdraulic sealant if that's not the right #. I've had better experience with than Teflon tape with my system, so your not wasting any money.
2. If that doesn't work, try the company again sending them the pics...
Otherwise, cut your loses and buy a new tank. Good luck with the company though.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 07-17-2011, 01:14 PM   #30
dragginmetal
Name:  DSCN1359 (640x480).jpg
This is one thats leaks.
Name:  DSCN1361 (640x480).jpg
This one dont leak.
I'm fixing to go get some loctite. We'll see how that goes.
Old 07-17-2011, 05:11 PM   #31
N2TRUX
Happy to be here
N2TRUX's Avatar
Who are you dealing with at AVS? I would have them send another tank.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-17-2011, 05:57 PM   #32
texastrendz
The tank fittings should seal with teflon tape. I would call them(company you bought it from) and discuss a solution. I can not tell you how many times I have had problems with parts. I know that sometimes parts are not always available locally, but when you can you always want to buy local. This is the reason why. I only buy steel tanks, that are U.S. built. I know the aluminum ones sound great, but you are not the only one with problems with them. Good luck, I feel your pain.
texastrendz is offline   Reply With Quote
Old 07-18-2011, 01:43 PM   #33
dragginmetal
Name:  DSCN1366 (640x480).jpg
I tryed some "Permatex high temp tread sealant". I let it dry for 4hrs then put 25psi in the tank. It worked better, but still pinhole leaks. Called AVS they said send them some pics. I sent them some and a link to this tread.
Theres not much locally around here. So where do i get a steel USA tank?
Old 07-18-2011, 09:37 PM   #34
texastrendz
Originally Posted by dragginmetal View Post
Attachment 775363
This is where living in Houston Tx comes in handy. I have a ton of suspension shops around me. I bought mine from Ekstensive metal works in Houston. I honestly can tell you that i will not give them another dime of my money, i had issues later on after i bought the tank from them on another project. You may want to check with some truck shops in your area. All the big trucks use steel air tanks on them for the accessories and brakes. If all else fails Ekstensive does have an online store. The product is great, the people just suck.
