Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-18-2011, 09:43 AM   #1
70shortwide
my combo
im putting a ls6 in my pickup and was wanting yalls opinion on my combo since this is my first ls motor.
2004 ls6
TEA stage 2.5 ls6 heads
eps 230/238 .600/.603 112+3
victor jr. intake
1150 domimator (i know its too big but its wat i got layin around)
6010 box
turbo 400
3800 stall (i think i need bigger)
9" rear with 4.11
200 shot
im hopin for mid to high 11's on motor and high 10's on n2o
truck weighed 3950 with big block and me in it
so tell me wat yall think?
thanks
70shortwide is offline   Reply With Quote
Old 07-18-2011, 11:02 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: my combo
Myself,, I think you better consider a roll bar in your budget
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-18-2011, 11:26 AM   #3
70shortwide
Re: my combo
the truck is already done is used to have a 555 big block and run 10's. so the truck and chassis are done im just swappin motors to make a little more street friendly.
Old 07-18-2011, 11:26 AM   #4
nomrlz
nomrlz's Avatar
Re: my combo
i think your expectations are very realistic if not slightly conservative
nomrlz is offline   Reply With Quote
Old 07-18-2011, 03:14 PM   #5
Super73
Super73's Avatar
Re: my combo
2004 ls6
victor jr. intake
6010 box
turbo 400
9" rear with 4.11
200 shot
thanks
Look at my numbers in sig..
347ci 11-1 cr
Ported 853 heads
243/250 .610/.612 (trex cam)
Super Vic (don't go vic JR unless you spend money to have it ported.
Dominator TB (it is not too big for EFI motor)
4L80E with 4,500 rpm verter
4.56 geared 12 bolt with 30" drag radial
I would personally do a custom cam. That EPS cam will not work great with a single plain..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-18-2011, 03:23 PM   #6
70shortwide
Re: my combo
well i called geoff at eps and was gonna have him spec me a custom cam but since i didnt wanna teardown shortblock to relieve pistons for valve clearance he suggested this cam.
so do u think my numbers are doable?
Old 07-18-2011, 08:56 PM   #7
Super73
Super73's Avatar
Re: my combo
That cam will work, it is just not optimized for that set up. I also hope you plan to run blended gas all the time and a very good race gas with that set up on spray. I'm assuming you will be running 62cc or smaller chambers, factory flat top pistons with no reliefs in them, .045 head gasket?
If so, this makes your combo 12.05-1cr with a DCR of 9.08 assuming a standard 50 or so degrees of duration for the hyd roller cam profile (some have a little less, some have a little more, but not by much).
You are asking a lot from a stock piston and rod even with upgraded rod bolts. As much as the saying big isn't always better, in this case, using a cam with a bit more duration can help reduce DCR. But the problem you have is those big valves on a factory piston.
I would honestly spend the money on a good piston with valve relief and a decent rod. Budget is great, untill something comes apart. If it's not in your budget right now, then don't spray much more than a 75-100 hit on it. Just my suggestion.
Old 07-18-2011, 09:56 PM   #8
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: my combo
What Super said. You can get some Scat rods and Forged probes for under $800.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-19-2011, 08:01 AM   #9
70shortwide
Re: my combo
well the heads havent been milled and im using a stock gm gasket. i really hope i dont have to run blended gas all the time cause that would defeat my purpose of making it more street friendly. i always use 110 or better for the spray. i prolly give it a 150 shot and see what it does surely it wont come apart the first time lmao. but rods and pistons deffinitely aint makin it this go round. hell 800 is bout what i gave for whole dang motor.
Old 07-19-2011, 07:49 PM   #10
Super73
Super73's Avatar
Re: my combo
A stock LS6 head is 64cc. If any milling is done even to sqaure up the head, my guess is they will be 62-63cc when finished, but for arguement sake, we will use 64cc (perfect brand new head with no milling or squaring).
A stock head gasket compressed is .054.
No valve reliefs.
Stock pistons for LS6's are normally pretty darn close to flush but generally people use -.005 (out of the hole .005) because thats what they normally come out to.
This comes out to 11.50 static and 8.67 dynamic. 8.7 dynamic is what I recomend as a max for 91 octane.
If the heads come in at 62cc's from being squared up, .054 stock gasket and -.005 out of the hole, you are at 11.93 static and 8.99 dynamic, requiring a blended fuel.
Going to a thicker heads gasket is not the answer either as quench becomes even more of an issue. Heck, you are already running a .054 gasket not helping that issue to begin with.
Do you have a degree wheel?
I might consider mocking things up with out a cam in place checking P to V every 2 * of rotation. Armed with that info any halfway smart cam manufacture could squeeze as big of a cam in there as possible reducing DCR.
Just trying to shed some light on things for you. The big valve stock piston is the killer. Adding more total duration would really help you as far as fuel.
Old 07-19-2011, 10:08 PM   #11
70shortwide
Re: my combo
thats good info. i wish i had talked to u more before i bought and assembled everything. oh well ya live and learn. im gonna have to run what i got for now but maybe this winter i can make some changes. there aint many people around here building these ls motors so i just had to do alot of reasearch and talkin to people. hopefully it will run pretty good and i can be satisfied till end of summer. thanks for your input.
