Old 07-18-2011, 09:47 PM   #1
jus2qwk
jus2qwk's Avatar
cant find a double clip master cylinder
cant find a double clip master cylinder at any of the local auto parts stores and the only one I can find is a single and the reservoir are different sizes.....my big brake line is in the back and that doesnt seem right for to big line to be with the small reservoir
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 07-18-2011, 10:13 PM   #2
jus2qwk
jus2qwk's Avatar
Re: cant find a double clip master cylinder
any help
Corey Jones Designs
Old 07-18-2011, 10:15 PM   #3
tasian
tasian's Avatar
some pictures might help i couldn't say for sure but it sounds like you may have a newer master cylinder
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 07-18-2011, 10:38 PM   #4
jus2qwk
jus2qwk's Avatar
what I need
what everyone has
Corey Jones Designs
Old 07-18-2011, 10:43 PM   #5
jus2qwk
jus2qwk's Avatar
I have disk breaks up front drum in the back and no brake booster
Corey Jones Designs
Old 07-19-2011, 03:40 AM   #6
tasian
tasian's Avatar
well this is what i used but i also used the matched brake booster but i don't see why it wouldn't work anyway that is the master cylinder for a 73+ any of your parts stores should have it
Betsy's build
Old 07-19-2011, 05:47 AM   #7
cdowns
cdowns's Avatar
resevoir the same size is for 4wheel disc brakes
Old 07-19-2011, 06:44 AM   #8
mcmlxix
Collector of Projects
mcmlxix's Avatar
Manual brake have a deeper hole for the pushrod to seat. Power brakes have a shallow hole because it mates the the booster, not the actual rod the connects tot he pedal... They were worried the rod could come unseated from the master cylinder, hense the deep hole.
Rich
1972 K5 Blazer CST Click HERE
Old 07-19-2011, 07:49 AM   #9
jus2qwk
jus2qwk's Avatar
hmmm I have always used a double clip and so has my dad, he even hod one that was square up front...... just wonder why I cant find one anymore, I know ccp has one and also have a nice custom one but im not sure which one to get if I cant find a double clip
Corey Jones Designs
Old 07-19-2011, 08:10 AM   #10
jus2qwk
jus2qwk's Avatar
If I order an aftermarket one what should I get.... a 1inch bore or what?
http://www.summitracing.com/parts/RSD-DBMC51C/
thinkg about that and if my rod is too long I think I might cut it down
Corey Jones Designs
Old 07-19-2011, 08:37 AM   #11
jus2qwk
jus2qwk's Avatar
anyone know if it will work?
Corey Jones Designs
Old 07-19-2011, 09:16 AM   #12
70cst
70cst's Avatar
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 07-19-2011, 12:18 PM   #13
jus2qwk
jus2qwk's Avatar
anyone?
Corey Jones Designs
Old 07-19-2011, 01:22 PM   #14
Fitz
Try here:
http://www.carolinaclassictrucks.com/mm5/merchant.mvc?
or here:
http://www.godmanhiperformance.com/
or here:
http://www.classicindustries.com/tru...?p=1&sb=0&r=15
Fitz is offline   Reply With Quote
Old 07-19-2011, 04:12 PM   #15
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I kept getting the 'newer 1 clip one' and orielly finally got me the 2 clip Mc
Dunno what it is. I like the look of 2 clip MC better though
John
1999 Toyota Tacoma 4x4
Old 07-19-2011, 08:17 PM   #16
71 super
71 super's Avatar
The double clip is a delco type cylinder, the single is a bendix type cylinder. They are in function the absolute same, the form is different and that is all. You can use the single clip in place of your original double and have no problem. The small bowl in the rear is for drum brakes in the rear and uses the larger line due to the lower need for pressure for the wheel cylinder. The larger cylinder is for the front due to the higher pressure required for disc and the smaller line causes the increased line pressure. Small equal high pressure, large line equal low pressure.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
