Synthetic or Regular Differential Oil
Is it ok to put Synthetic in my differential after it has been running fossel based, regular oil for so may years? I heard it will looseen seals, cause leaks, etc.. if you switch midway through with any engine.
![]() Join Date: Feb 2001
Re: Synthetic or Regular Differential Oil
Some reading for you ...
fluids/oils/gear lube http://67-72chevytrucks.com/vboard/s...d.php?t=177957 someone please tell me this guy is full of BS http://67-72chevytrucks.com/vboard/s...d.php?t=378304
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
its all about the +6 inches
synthetc oil is the best thing you can do for your diff.
i use synthetic lubrication in everything motor tranny rearend and also wheel bearings// have had noticable increase in milage and slightly more performance in my real world test uses
the last two new GM vehicles i got came with synthetic right from the GMfactory//2004silverado and 2008 HHRss
20' Daredevil (Ret)
![]() Join Date: May 2003
My K20 had dino in the diffs (& t-case) for close to three decades before I changed to synthetic. No problems....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Right on, synthetic it is. Thanks!
#9 | ||
"I ain't nobody, dork."
Unless it has a positraction rearend. Some Synth oils aren't compatible with a positraction diff. Or the other way around...
Gary
most all synthetic i know of is no problem in posi rears in fact most you dont even need a posi additive like you do with dinogrease
yeah... I've never heard of that one. Sounds like yet another one of the millions of myths about synthetic oils.
Grandpa in the rustmobile...
great my parts guy told me synthetic is a fluke and i put dino in my diff lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Eat, Sleep, Drive a Chevy
I am running Redline Heavy Shockproof in my rear, its a posi and did not do the additve as directed by the shop that built the rear. The owner told me he tested diffrent brands at the track and the Redline proved to run cooler thus working better to reduce friction
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
