Old 07-12-2011, 11:14 PM   #1
rchavez101
rchavez101's Avatar
Manual to Auto transmission crossmember ?
I am in the process of gathering info for my tranny swap from a manual to a 700r4 and I am wondering if the cross member is different or does it need to be rolocated with different mount on the cross member. Please let me know thanks.
rchavez101 is offline   Reply With Quote
Old 07-13-2011, 07:05 PM   #2
rchavez101
rchavez101's Avatar
Re: Manual to Auto transmission crossmember ?
I know someone knows the answer.
Old 07-19-2011, 12:32 PM   #3
bubba353z
bubba353z's Avatar
I'm doing searches here for the same project.....
I found one thread (so far) that says you have to remove the manual crossmember, which makes sense. Looking at my 68' (w/ 3 on the tree) it has two side mounts to the manual's case, whereas the 700 has a single mount on the tailshaft.
I'm looking at a CPP tubular mount right now.... Others will likely suggest different options
bubba353z is offline   Reply With Quote
Old 07-19-2011, 02:52 PM   #4
rchavez101
rchavez101's Avatar
I heard that you have to move the crossmember back but put a different mount for the 700R4. When I look under the truck there are different holes on the frame to move the crossmember back or forward. I have not been able to verify if that is true or not. I know some on the forum has gone from manual to Automatic but unsure how they did it.
Old 07-19-2011, 07:42 PM   #5
bubba353z
bubba353z's Avatar
Yeah, the 700 is longer than a 350/400 - but it's only two holes per side to drill (at most).
The 700/350/400 use the same rear mount. Check out Energy Suspension:
http://www.jegs.com/i/Energy+Suspens...1108G/10002/-1
