Old 07-19-2011, 10:57 PM   #1
camshaftgsxr
camshaftgsxr's Avatar
axle to bottom of frame hight
i really need the measurements from the top of the axle tube to the bottom of the frame on a stock truck, i cannot figure out how low mine is in the rear and this may be a good place to start.
thanks all
camshaftgsxr is offline   Reply With Quote
Old 07-19-2011, 11:37 PM   #2
67_SS396
Re: axle to bottom of frame hight
If you don't get measurements by morning, I'll pull them for you. Mine is a 2wd short bed if that's what you're looking for.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 07-19-2011, 11:52 PM   #3
camshaftgsxr
That'd be great! Even if your truck is lowered, if you know how much I can do the math!
Old 07-20-2011, 09:04 AM   #4
67_SS396
My truck has no drop yet and it measures 9.25" from the top of the axle tube to the bottom of the frame. There is about 100lbs of weight in the bed and the fuel tank only has about 3 gal of fuel in it. Hope this helps.
RevLimit Offroad
Old 07-20-2011, 05:52 PM   #5
camshaftgsxr
My measurements came to 4.75 inches from tube to frame,
Ane there any ways to accuratly measure the front suspension?
Old 07-20-2011, 11:04 PM   #6
67_SS396
Could measure from the ground to the bottom of the front cross member, then figure out the difference in tire size between yours and mine.
RevLimit Offroad
