Old 07-20-2011, 01:54 AM   #1
sixshooter798
Desert Rat
sixshooter798's Avatar
Junkyard Score
Got the necessary stuff to do my swap to the 73/74 grille today! All the grilles I found were toast, but the mounting brackets were all there, as well as a couple emblems! What did they charge me? $15.
I've started cleaning up the emblem on the right.
sixshooter798 is offline   Reply With Quote
Old 07-20-2011, 06:48 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Junkyard Score
Did you get the latch too?, cause you will need it. If your truck has an internal hood release, you'll need the filler panel too.
bigblock73 is offline   Reply With Quote
Old 07-20-2011, 10:49 AM   #3
kris's66lwb
resident wrencher
Re: Junkyard Score
I took my orginal hood relese bracket and hacked it off to accomidate the grille i just need to get the side bractets seeing as how the center brackets dont line up with the 80s core suypport
kris's66lwb is offline   Reply With Quote
Old 07-20-2011, 12:34 PM   #4
BigRed76
BigRed76's Avatar
Re: Junkyard Score
What did you do to clean up the 350 emblem?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-20-2011, 12:59 PM   #5
bigblock73
yeller
bigblock73's Avatar
Re: Junkyard Score
Soak it in brake fluid, strips off all the paint easily.
Old 07-20-2011, 01:56 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Junkyard Score
Nice find that aint bad at all and those emblems will look pretty cool.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-20-2011, 03:13 PM   #7
sixshooter798
Desert Rat
Re: Junkyard Score
I have an external hood release. I didn't see anywhere that I needed to swap the latch assemblies, but I'll go back and get it if necessary.
Old 07-20-2011, 09:31 PM   #8
bigblock73
yeller
bigblock73's Avatar
Re: Junkyard Score
Read Kens retro tech article, it covers it pretty good there. You won't be able to run your external release...get the latch and filler panel to complete the swap.
Old 07-20-2011, 09:41 PM   #9
sixshooter798
Desert Rat
Re: Junkyard Score
From reading his article, it seems that if I had an internal release latch I would need to swap some stuff out. The article does not indicate that a 77 external release will not work.
Old 07-20-2011, 10:16 PM   #10
bigblock73
yeller
bigblock73's Avatar
Re: Junkyard Score
OK, you said you had an EXTERNAL (and I even said that, but was thinking you had an internal), sorry...so go back and get the latch, that will be all you need.
Old 07-21-2011, 12:23 AM   #11
sixshooter798
Desert Rat
Re: Junkyard Score
Whats the difference in the latches?
Old 07-21-2011, 12:40 AM   #12
bigblock73
yeller
bigblock73's Avatar
Re: Junkyard Score
How they connect to the center brace...
Old 07-21-2011, 01:31 AM   #13
sixshooter798
Desert Rat
Re: Junkyard Score
Well alright. My grille will be here in 3-7 business days, and I'll go back to the junkyard when it arrives. There were 3 of them lined up for me, so I doubt all 3 latches will be gone by then.
Old 07-26-2011, 02:42 AM   #14
sixshooter798
Desert Rat
Re: Junkyard Score
The OEM latch in my 77' works just fine...
Old 07-29-2011, 07:28 PM   #15
rcsweet21
Re: Junkyard Score
I have a grill for a 1978 chevy if they need it
rcsweet21 is offline   Reply With Quote
