07-20-2011, 01:23 PM | #1 |
68 C-10 with Hotchkis kit and CPP front end wheel ?
I have a 1968 C-10 2WD pickup that has factory drum brakes front/rear. It is a 6 lug truck. I have a Hotchkis kit for it part number 80390 and ordered from CPP front disc brakes with 73-87 spindles (not drop). I was told that the factory rally wheels won't work but am habving a hard time finding other wheels for the truck.
ANY help would be greatly appreciated. Thanks |
07-20-2011, 03:52 PM | #2 |
Re: 68 C-10 with Hotchkis kit and CPP front end wheel ?
Now I might be switching over to 5x5 bolt pattern and switching the rear to disc brakes as well. Does anyone know what offset / back space I would need on the wheel ? I wanna do factory style rally wheels and where I can get them .
Thank you Last edited by wbwisme; 07-20-2011 at 04:01 PM. |
07-20-2011, 11:54 PM | #3 |
Grandpa in the rustmobile...
i dunno what your asking but im running 72 bj's and spindles with 5 lug rally truck wheels
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-21-2011, 12:19 AM | #4 | |
Factory ralleys should work w/factory disc brake set-ups (5x5 lug 71-87 spec'd stuff). Drop or aftermarket spindles can effect back-spacing requirements.
07-21-2011, 11:50 AM | #5 |
was told that the factory drum wheels on the truck wont work with disc brake conversion. Think it hits the caliper. Not sure if I were to space it out how much I would need to space out factory rim. Trying to figure out backspacing issue if I keep the 6 lug disc brake conversion that I would need to get on the rims.
thanks |
07-21-2011, 12:47 PM | #6 | |
6-lug, pre-71, steel wheels won't work w/disc brakes as they were spec'd for drum brake set-ups. They could prob be used w/a spacer but wouldn't be the best option. The post 73 4x4's did have a solid steelie that's very similar to the drum brake steelies that does work w/disc brakes. These are difficult to find used.... If you want a solid steelie that works w/disc brakes & doesn't require spacing, try purchasing them from an aftermarket source like WheelVintiques. 6-lug ralleys were used from 73-87 on 4x4's & will fit your disc brake swap.
07-21-2011, 12:53 PM | #7 |
sorry, I have the factory rally wheels on the truck now (small rectangle openings).
07-21-2011, 01:53 PM | #8 |
The 5 & 6 lug ralley wheels (w/the small retangular openings) do work w/disc brakes. No spacers needed....
07-21-2011, 02:01 PM | #9 |
Thanks for the replies. you guys
07-21-2011, 02:37 PM | #10 |
A nice pic to show what wheel may/may not fit.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
07-22-2011, 01:13 PM | #11 | |
wbwisme - Thanks for your business. You should call Rob Phillips at Phillips & Co. Hot Rods or contact him here (PM PCHRODS). Rob has a really slick C10 and is building another for a customer, so he would be the guy to ask about wheel offset and backspacing. His fitment is right on. 562.590.6200 |
07-22-2011, 05:16 PM | #12 |
Hey sounds like you'll have a nice project. I've been thinking about the Hotckins front A-arms but they are pricey. Where did you buy your stuff from? The best prices I could find are from Summit. Thanks, Nate
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
07-25-2011, 01:30 PM | #13 | |
Nate - Thanks for thinking about our control arms. They are a really great upgrade. We have a lot of distributors that have special deals and discounts. If you shop around you can get Hotchkis products for a great price. |
09-03-2011, 11:49 PM | #14 | |
On our truck we run a 19x12 rear with 5" b.space and a 19x10.5 front with 5" b.space. 335/30/19 Nitto NT05's out back and 285/35/19 up front. and yes this is on a stock rear end in a 69 C10 with no rubbing. We have ran 345/30's (13.5" wide tire) in the past, but do run into minor rubbing on the inner wheel house on the bed. 70-72 truck are different because the rear end is wider than a 69 and older. Let me stress this though, always measure...measure...measure before you order wheels it's really easy to do, and this way you only have to order wheels once!! If you have any questions at all feel free to email rob@pchrods.com and I will try and help you out with anything I can. Rob |
09-04-2011, 03:58 AM | #15 | |
Let me start out by saying....and you can quote me all day long on this too!! "Hotchkis C10 components are worth every red cent" I have ran several different brands of products on our truck, but we now have the complete Hotchkis TVS Suspension System, and i will tell you this. You will not find a better handling suspension for the C10. The upper and lower control arms to me are the heart and soul of this kit. Don't get me wrong, all the other components are definitely needed to get the "full" potential for the handling characteristics. If you want to see for yourself go to youtube and type in PCHRODS in the search and look at all the videos of our truck, i think you too will be amazed. the OUSCI videos really show you some impressive moves for a 4280 lb truck. |
09-04-2011, 12:38 PM | #16 |
Hey Rob,
Along with the TVS kit you run what else have you done to achieve that stance? Your truck is perfect! Brandon
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
10-28-2011, 08:59 AM | #17 | |
