Old 08-04-2003, 05:11 PM   #1
Chevyguy111786
Rear diff oil change?
how do i change my oil on my rear diff? i've got an idea of how to do it. but i want to do it right and not screw it up. chevyguy
Chevyguy111786 is offline   Reply With Quote
Old 08-04-2003, 05:25 PM   #2
69mychevy
yes i did post something
i might be wrong, but it takes me about 32.6 seconds to do a rear differential gasket change, so when i have to do the oil back there, which isn't often i just change the gasket too, am i wrong here?
you can want in one hand and s h i t in the other and see which fills first
NO MATTER HOW BEAUTIFUL THE GIRL(S) IN MY AVATAR IS PLEASE READ MY POST
69mychevy is offline   Reply With Quote
Old 08-04-2003, 05:30 PM   #3
Yukon Jack
Yukon Jack's Avatar
First, see if you can get a gasket, otherwise you will have to use gasket in a tube. Leave one bolt at the top of the cover loose so when you get the rest of the bolts loose, the cover will hang rather than dropping. Have a big oil pan as the lube will come out fast. Not a lot of lube but it does gush out usually.
After draining, get gasket surface prepared and cleaned. Reinstall and then fill with at the fill plug. I found a pump you can attach to a gear lube bottle which sure makes it easy to fill the diff back up.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-04-2003, 05:45 PM   #4
COBALT
COBALT's Avatar
...and fill it to the bottom of the hole (it starts to drip out, or you can feel it with your finger.
Silicone II Window/Door sealer (blue/black tube). Works like a charm.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-04-2003, 11:15 PM   #5
Chevyguy111786
That's what i thought...THANKS GUYS!
