07-22-2011, 03:41 AM | #251 |
Master Procrastinator
Re: Finally starting the 68swb fleet
looking forward to pics, I put the motor and tranny in, the parts store shipped the wrong rocker nuts and harmonic so I'm still at a stand still, I'll post pics tomorrow
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
07-22-2011, 04:13 AM | #252 |
if i heard you correctly you said you ave the engine and tranny in the frame?
07-22-2011, 04:34 AM | #253 |
well it is but it isn't, the tranny is just temporary for mock up, headers won't work without a real restrictive bend off the collectors so they'll be replaced pre start up and as always, I was shipped wrong parts so I'm at a stand still there and my electrician has been so swamped he hasn't had a chance to get the welder in yet, gives me a chance to clean the garage out though The holes in the frame could allow me to run these headers by moving everything back, but I will know when I mock up the driveshaft tomorrow, my teardown pics look to have everything where it is now, the monte carlo/chevelle style shorty headers look like the right fit for my dilemma if not and I should be able to sell these and break even up here so not to worried
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project Last edited by tantrumpipeline; 07-22-2011 at 05:34 AM. |
07-22-2011, 12:23 PM | #254 |
Needs a Big Block
I ran hooker 4266. Shortys a few times , but I was using 73+ engine mounts, They fit awesome and were a breeze to run the exhaust tucked up into the frame looking sweet buddy!!
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
07-22-2011, 02:34 PM | #255 |
thanks, I may do the same, but the swept style shorty's may be the best way to flow with the crossmembers I have etc, going to see what offers I get locally on my shortys and if I come close to breaking even I will upgrade to ceramic coated as well to save on starters and plug wires
07-22-2011, 04:37 PM | #256 |
Needs a Big Block
Sounds good!! Those hookers I mentioned are a 3/4 length swept shorty , I had em on a bagged shorty ( my 64) And ran the exhaust up in the frame that being said ,get this thing fired uppppppp!!!
07-22-2011, 06:05 PM | #257 |
outta money lol dammit Starting work again tomorrow though, may have some parts sold etc to cover a carb and the rest of the motor parts so we'll see, hoping to do some bodywork for the time being once my welder is setup
08-13-2011, 11:40 PM | #258 |
Can't believe you even though a out selling,
Who doesn't like an endless money pit and no garage space. And by the way i can tell that you Are logged in. That means you are not working in the garage. Posted via Mobile Device
67' Shortbox build thread:http://67-72chevytrucks.com/vboard/s...=1#post4281123 |
08-13-2011, 11:48 PM | #259 |
waiting on a day off now to wire in the welder and order some more parts, had a mishap with my right hand though so not in a rush, hoping to get everything in next sunday and start on the cab though, gonna learn to weld left handed if thats what it takes, they make grinders and flap wheels for a reason Yeah it was close to going up for sale, but the sun finally came out to play so I am back to work, woulda been a fight to the bitter end had it come to that, the joys of being in business for yourself
09-05-2011, 11:57 AM | #260 |
I have been too busy to work on it lately but I just picked up the wire needed to hook up my welder and I'm looking at a few 60gal compressors, going to sit down and make an order list for my intake pipe plugs, rocker nuts, alternator,and water pump sp hopefully I can give it a test run, and weld up the cab before the snow comes.
09-08-2011, 09:42 AM | #261 |
67cheby
just my 2 cents ....if you are going to do body work you need atleast an 80 gal compressor the 60 gal ones i have had wont keep up with air sanding tools, you will be very annoyed waiting for the compressor to keep up !! now maybe it was my compressors that i tried they were new BlackMax compressors, when i switched to the 80 it worked great
09-10-2011, 12:11 AM | #262 |
thanks I'll look into one
09-10-2011, 12:38 AM | #263 |
GEARHEAD
My 60 gal worked well for me. 80 is better, but not sure the added cost justifies the expense for most home shop users. The 80's are usually a 2 stage pump and much more expensive. BTW, I inspect these things for a living and worked at a plant that builds them for a few years. The key is the pump. A good 60 gal should have a good 2 cylinder pump. They won't build the pressure of a 2 stage, but have good capacity. Also, most air tools don't need the full tank pressure, so using a line regulator set to around 100 psi will generally help the air usage. The only time I had air pressure problems was when I was sand blasting or running the random orbital non-stop. I usually had to stop to change sanding disks etc. anyway, so not a huge problem.
Hope this helps.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
09-25-2011, 07:42 PM | #264 |
thanks I will keep that in mind, this project is somewhat back on the shelf, too busy and a lot going on, maybe get back into it this spring, if anything changes the pics will continue
05-10-2012, 12:16 AM | #265 |
back from the winter, rear fenders and step plates should be in within a week, cab is going back to sandblast to get the inner and outer floors blasted to remove whatever coating was sprayed on so I can re coat with POR15 and repair a few minor spots, electrician is tentatively lined up to have the welder setup next week, we have heard this before though, and I should have a week or two off starting monday so this thread will once again be active, I'm hoping to have the cab repaired, smoothed firewall, and back on the chassis by the end of may long, the weather is nice at last, as always the pics will be plentiful, also have a binding issue with the steering I need to get squared away
05-10-2012, 01:49 AM | #266 |
great progress man lovin how good the chassis looks and motor is comin along nicely
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
05-10-2012, 06:01 AM | #267 |
67cheby
Awesome looking forward to the progress
Posted via Mobile Device |
05-10-2012, 10:57 AM | #268 |
Thanks guys, the time away from it has got me motivated again, maybe one more snowmobile trip then it's all truck until wakeboard season
05-10-2012, 11:31 AM | #269 |
I'm definitely subscribed! Living in AB maybe I'll get to see it in person one day! Keep up the great work!
05-17-2012, 05:31 PM | #270 |
Slacking pretty hard on this build but I hope to have it on the road one day, this forum is a blessing and a bad distraction with all the other builds you drool over you end up changing and adding all the time Got a delivery from AMD with my rear fenders step plates and braces, now I'm waiting to hear back from a local blaster to hit the bottom and inner floor of my cab so I can get to repairing issues and smoothing out the firewall
05-17-2012, 06:09 PM | #271 |
nice bunch of parts! .... you have been slackin.... HARD lol get back on the ball tyler! lol
05-17-2012, 06:15 PM | #272 |
hahaha I'm trying, now the issue is nobody in town wants to blast for me due to the nature of the job and issues with warping, hopefully hear back soon
05-19-2012, 04:32 AM | #273 |
hopefully!
05-25-2012, 10:21 AM | #274 |
Stripping old undercoating is tedious crappy work, sandblasting in GP is ridiculous right now, backlogged til early July and my A.D.D. won't let me wait til then and the cab really isn't in bad shape so I am at it with grinding/stripping/and wire wheels
05-25-2012, 10:41 AM | #275 |
67cheby
nice work, keep it up !
