Play it Loud...
Help with Horn install...
I'm installing a new horn and need a little help. This is quoted directly from the instructions...
"Connect the Orange wire to any wire that has a constant positive 12 volts (not an on/off wire)." Now as simple as this sounds, I haven't done anything like this before. Closest I've done is hooking up my stereo, but that uses "an on/off wire". Any suggestions on which wire I could use? Obviously I don't want to go directly to the battery in case it sucks up too much juice. Thanks
Big Moe =-=-=-= 1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint. 1952 Chevy Pickup waiting to be brought back home! |
Actually the stereo should have used a constant power for the memory.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
It followed me home?
stereo should have used both, run it to the fuse box and put an inline fuse. Your fusebox should have an empty space with constant power.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Professional Grade
If not, and you have enough cable, hook it up to your cigarette lighter cord... Same with the memory wire off your stereo...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
You get what you pay for
![]() Join Date: Dec 1999
In the fuse box, you will have open spaces labeled ign and bat. The ign slot is hot only when the key is on. Bat is always hot. Put a male spade connector on the wire and plug it in the bat space.
Mike 1985 Chevy C-10 |
was your truck not equiped with a horn or what? what kind are you trying to install? OEM? or aftermarker air horns?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Play it Loud...
Thanks everybody for the responses, yes, it's an aftermarket horn. I still have my stock horn and all, but I just wanted to add this one.
BeWarE tHe eViL CrAnkTOe!
HOOOOOOOOOOONNNNNNNNNNNNK!
hahaha sorry no help from me on this one!! lol
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
tie it into the same power supply for your original horn.... unless you are wanting them seperate.... with the aftermarket one on a switch... i just tied mine into the stock wire...
HoOOOOOOOOOOOONNNNNNNNNNNNNNKKKKKKK!!
hahaha..
LED King
Sounds like my friend who put an awooga horn in his honda.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
I wired a 6v. VW horn into my stock horn wire. They sound reeeeally obnoxious together.
haha @ jim... then dont use both.. just the power wire..
