Old 07-23-2011, 05:09 PM   #1
68steppsidee
Just got upper and lower control arms
I bought them off craigslist pretty sure they'll work for my truck i'll post some pics. But i believe they are drop control arms so if i had drop spindles would this be over kill or just fine thanks for checking it out and your input!!
68steppsidee is offline   Reply With Quote
Old 07-23-2011, 05:10 PM   #2
68steppsidee
Re: Just got upper and lower control arms
truck is a 70 frame but 67 front end stepside truck
Old 07-23-2011, 07:01 PM   #3
lilpoindexter
lilpoindexter's Avatar
Can you post some pics of your wheels, and tell us more about them?
lilpoindexter is offline   Reply With Quote
Old 07-23-2011, 10:13 PM   #4
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Are you going to run bags?
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 07-24-2011, 09:15 AM   #5
68steppsidee
yeah gonna run bags wheels are 8 in corvette ralleys i'll get pics
Old 07-24-2011, 09:28 AM   #6
68steppsidee
These wheels arent on yet but here's a pic of my truck work in progress
Old 07-24-2011, 10:34 AM   #7
68steppsidee
anyone
Old 07-26-2011, 06:23 PM   #8
68steppsidee
still nothing
Old 07-26-2011, 10:20 PM   #9
Sammy
They appear to be upper n lower tublar control arms with bag plates. If they are correct for your truck year it is hard to tell. And yes you will want dropped spindles with that setup. Also front disk brakes while your there. You may possibly need the tie rod adapters if your tie rods are the 67/68 version. Hope your not running short on cash you are embarking on some expensive upgrade. Plus bagging the back plus the airide setup. Good info with lots of knowledge over in the suspension side if your looking on how n where to start.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-27-2011, 07:17 PM   #10
68steppsidee
got a pretty good start of know how from friends and family with bagged projects. already have disc its a 70 cab and frame pretty sure i have it figured for the rear somewhat any more help... also i have long tube headers i know it wont lay frame with the way it is but not a huge thing i figured go all the way down til i lay header for know??? is that possible..
Old 08-04-2011, 01:42 AM   #11
firedog
firedog's Avatar
My truck has long tube headers with my pipes tucked up and they pass thru the trailing arm crossmember to keep em up off the ground my truck sits barely on the headers an bottoms out on the tires in the fender
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 08-04-2011, 01:03 PM   #12
tubbedII
needs more $$$
tubbedII's Avatar
With my 22's, drop spindle and bags, My long tube headers are 1/4" from hitting the ground when aired out. If those lcas have any drop built into them, you might hit/crush your collectors. Usually, you can lay the lcas on the ground with about 2" or so drop built into them. Only way to tell now is to get it all installed, so hurry up and take some pics so we can all see!!!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 08-05-2011, 10:56 PM   #13
68steppsidee
will man im training to be an electrician so im busy alot
Old 01-09-2013, 09:05 AM   #14
70blackfish
did your A arms Work?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-14-2013, 06:46 PM   #15
68steppsidee
yeah but im selling them ive got porterbuilt suspension coming tom.
