07-23-2011, 08:24 PM | #1 |
Overflow tank?
Where is the correct location for a coolant recovery tank on a 69 c10{if it had 1?}.Got a aftermarket 1 but does not seem to really fit anywhere practical.
07-23-2011, 08:28 PM | #2 |
Junior Member
Re: Overflow tank?
Didn't have one from the factory. Some people put them on the radiator core support and others put them on the opposite fender from the window washer bottle.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
07-23-2011, 10:07 PM | #3 |
~Rest In Peace~
Re: Overflow tank?
i just bought one from jegs with the bracket im going to mount mine where the battery used to be
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-24-2011, 12:21 AM | #4 |
Re: Overflow tank?
i may be wrong but ....front portion of the passenger wheel well 'tub'... sits right behind the battery...
07-24-2011, 03:07 AM | #5 |
English Chevy Owner
Re: Overflow tank?
Some pictures of peoples would be good as I've just bought one from summit racing and haven't got a clue where to mount it, the current bottle (old coolant bottle!) is tucked in the passenger fender
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
07-24-2011, 03:32 AM | #6 |
Stalker Nate
Re: Overflow tank?
Various on the truck but it's an option from what I've seen. Not mandatory on any of them. Typically it bolts to either the driver's front fender or passenger side front area. Just after the battery beside the wheel well. I've found them on both sides from the factory.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
07-24-2011, 04:23 AM | #7 |
Re: Overflow tank?
It would be a lot easier to have it near the cap, on the passenger's side, so you wouldn't have to run the hose across the top of the radiator.
Here are a few that I've saved:
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
07-24-2011, 06:43 AM | #8 |
Re: Overflow tank?
I got a universal one from NAPA and it fit between the battery and the pass. fender (just barely).
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
07-24-2011, 09:21 AM | #9 |
SWB 4x4 Collector
Re: Overflow tank?
The optional/dealer installed tank, was typically mounted to the radiator support on the driver's side, just about where a second battery tray would mount. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
07-24-2011, 11:40 AM | #10 |
its all about the +6 inches
Re: Overflow tank?
i've only seen proof of one factory one, and it was a gov truck. All the rest were dealer installed, or more likely, parts store stuff. You can still find them that look much like the dealer parts pieces.
07-24-2011, 12:26 PM | #11 |
Active Member
Re: Overflow tank?
Two options on my GMC. The second pic is what I have right now. Spent $10 at Lowes on it.
07-24-2011, 12:36 PM | #12 |
English Chevy Owner
Re: Overflow tank?
I was wondering if anyone had put theres the front side of the core support as I was thinking about mounting mine there, Looks like a goer, mines a black Summit 1 quart job so won't be too obvious from the grille.
07-24-2011, 06:50 PM | #13 |
Re: Overflow tank?
Here is a picture of the dealer installed GM tank. It is identical to the version Andy mentioned on the government truck. I bought this one several years ago it was NOS sealed in the GM box. It mounts on the core support just above the horn as trevor stated in about the same location as the aux. battery tray. I also included some pictures of the truck just because
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
07-24-2011, 07:26 PM | #14 |
Re: Overflow tank?
I to have a nos set up and the instruction sheet shows it goes right where 71 super has his.
07-24-2011, 07:30 PM | #15 |
Re: Overflow tank?
I find myself in need of one too, didn't have one when i bought the truck..... so you can purchase one from napa over the counter?
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
07-24-2011, 09:20 PM | #16 |
Re: Overflow tank?
Bought one from summit. Saw another post that someone used a metal water bottle, another that they used one of the new aluminum beer pints with the screw on lid. Here is some pictures of my installation. Mounted off the factory battery bracket.
07-24-2011, 10:56 PM | #17 |
Stalker Nate
Re: Overflow tank?
I didn't know these were so rare lol Most my trucks have had one hahaha
07-25-2011, 01:42 PM | #18 |
Re: Overflow tank?
The GM version is pretty hard to find. The others pictured are parts store units and available almost every where. The GM unit is pretty big and has a dedicated bracket/holder to support on all sides as well as the bottom.
07-25-2011, 02:17 PM | #19 |
Re: Overflow tank?
The one I bought is from LMC,it will not fit on the overflow side of the radiator.It will have to go on the drivers side and route hose.It seems rather oversize?
07-25-2011, 05:17 PM | #20 |
///Relaxed Atmosphere
Re: Overflow tank?
71 super thats one beautiful truck, can i see more pics of that overflow? and where did you buy it from if you dont mind me asking? i want something close to stock also.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
07-25-2011, 09:43 PM | #21 | |
Stalker Nate
Re: Overflow tank?
I got a few of the GM ones so they aren't rare to me Never seen any other kind on any of the trucks I've bought. And to think I was just going to throw them out cause I figured everybody had one
07-25-2011, 10:22 PM | #22 |
Re: Overflow tank?
Original 71 I got the tank off of ebay a couple of years ago. Let me look back through some photos and see if I have more of the tank.
10-30-2011, 04:45 AM | #23 |
Re: Overflow tank?
The one i was just overcharged for($28) by LMC is a pc of Taiwan crap. Only one of the holes lined up and the cap wont snap on. Even the plastic is paper thin unlike the originals. Supposed to be a factory replacement for my 75 C10. The last one i bought from Classic Ind. was better made. I think this is the last one i will buy. Next time i will make something. Poor quality products fall by the wayside.
10-30-2011, 09:37 AM | #24 |
Re: Overflow tank?
Don't have a pic of it but I installed mine on the passenger side just aft of the battery. Used a w/s washer tank and bracket. Looks stock and matches the factory washer tank on the driver's side. Just don't get confused and put anti-freeze in the driver's side tank.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
10-30-2011, 12:33 PM | #25 |
Who's got steelies?
Re: Overflow tank?
I used a washer fluid bottle and mounted mine next to the battery. It works and looks stock to those who don't know.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
