07-23-2011, 10:54 PM | #1 |
Proportioning valve ??
Will a disc brake proportioning valve work OK on drums front and rear?
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb |
07-23-2011, 11:00 PM | #2 |
~Rest In Peace~
Re: Proportioning valve ??
its a disc to disc PV or is it disc and drum PV ,i would think it would work being disc pv .
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-23-2011, 11:48 PM | #3 |
Please don't mix brake parts. You need those important safety parts to work correctly. Each brake component is designed and manufactured for a specific purpose and should not be mixed up. Easier to find the right part than to recover from an accident.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-24-2011, 06:28 AM | #4 |
Drum brakes and disc brake require different pressure characteristics and the purpose of the proportioning valve is to keep the pressure in the proper "proportion" in the two separate sides of the system controlled by one master cyl.
07-24-2011, 11:39 AM | #5 | |
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
07-24-2011, 12:06 PM | #6 |
67-72 parts collector,…
Drum brake trucks have a distribution block.
It's not a proportioning valve. Meaning,... it doesn't regulate the front vs rear brake pressures,... it just sends fluid to the 4 wheels. Use the correct parts on your drum brake truck.
07-24-2011, 12:12 PM | #7 |
What about using differentials from a truck that came with anti-lock brakes? Will the discs work fine with a stock 71 setup?
07-24-2011, 12:23 PM | #8 |
as stated use the correct part. Prop valves send 70% to the front and of course 30% to the back. Disc brakes need more pressure up front than the rears. So all you are doing is sending that to the front on drums which is not needed. the part is not expensive so use the correct one
07-24-2011, 12:25 PM | #9 |
