Old 07-24-2011, 04:29 PM   #1
Eddie H.
Eddie H.'s Avatar
Another variation of the Gas Filler Relocation.
For those who are installing a tank under the bed, and don't want to put a door on the outside , or go to the trouble of hiding the filler behind the marker light, tail light, or license plate, here is a quick, cheap, easy, "semi hidden" solution.
1. Atwood, angled marine deck filler neck, with vent. $ 27 off of ebay.
2. Cut a hole for the hoses in the left rear corner of the bed floor.
3. Fab up a simple enclosure from some scrap sheet metal.
4. Either screw or tack weld it in, and finish to match. ( this one will be covered with spray on bedliner, so being a little rough won't matter)
It is easily accessable, and with the tailgate shut, it's barely even noticeable.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 07-24-2011, 04:46 PM   #2
Goats86
Re: Another variation of the Gas Filler Relocation.
Looks great. I did a similar method on my 86. I baked it for 45 minutes after a rattle can finish. Amazing how durable it is.
Goats86 is offline   Reply With Quote
Old 07-24-2011, 05:02 PM   #3
mrhino
mrhino is offline   Reply With Quote
Old 07-24-2011, 05:05 PM   #4
budnikguy
budnikguy's Avatar
Dang..I like all 3 of those!! Good work to you all...
budnikguy is offline   Reply With Quote
Old 07-24-2011, 05:45 PM   #5
bbadfred
bbadfred
bbadfred's Avatar
Heres what I did since the bed will be used for light duty hauling. Bed liner is planned for inside the bed. The bump is to clear the ford 9" Moser housing and the plate is for the fuel pump access
bbadfred is offline   Reply With Quote
