07-24-2011, 04:45 PM | #1 |
Trans swap!
I have a question for the guys that have kept there inline 6. I want to keep my 230 for a while and see how the gas prices go or at least till I get a beater. I have the stock 3 on the tree and I wanted to go with an automatic. I picked up an axle with posi and a 3.90 gear. I want to go with a 700r4 as I see a lot of guys on here do. My bro says he can get a turbo 350 trans already rebuilt for bout 700 bucks. He says I should go that way anyhow. He says it won't make a diff. I say there has to be a reason all the posts I see on here go with the 700 trans. What do you all think and can I mod the old column or use one out of a newer truck that isn't so expensive as these replacement models?
07-24-2011, 05:48 PM | #2 |
Re: Trans swap!
depends what you want to do with the truck. If you will be on the highway AT ALL(!) I'd personally go with the 700. If it's just to put put around town, the 350 will be fine and save you money (in up front costs anyway). The 700 WILL save you money on gas if you get much highway time. The difference is the overdrive aspect of the 700. TH350 has 1:1 final drive, 700R4 has overdrive ratio .70:1 (or close to that). But for instance - WHATEVER your combo is (rear end, etc):
- "3rd" gear will be the same rpm in the truck with either trans. - and whatever speed you get to on the highway that gives you 3000 rpm with the TH350, for example - that SAME speed would be achieved at only 2100 rpm with the 700 because of the .70:1 o/d ratio. Hope that helps. There is a little more cost and a little more setup involved in the 700 - but if you will see >60 mph very much, I think it's worth it. Especially with a 3.90 rear end. Last edited by jocko; 07-24-2011 at 05:54 PM. |
07-24-2011, 06:36 PM | #3 |
Re: Trans swap!
If I guy was to put a th350 in a truck with a I6, what would be the best gear to put in it? My currently has stock rear gears( whatever that is?) I'd like to do the same as the OP. But I may end up driving soem hiway. Thanks.
07-24-2011, 07:21 PM | #4 |
Re: Trans swap!
Thanks for the reply! I will being driving the highway. I will drive this truck a lot. Prolly everyday. I am leaning toward the 700 with the more posts I read. What are the things to look for when setting this up. You mentioned that thgere is a little more set up involved with the 700 r4.
07-24-2011, 08:17 PM | #5 |
Senior Car Nut
Re: Trans swap!
Jel, more thoughts. I'm not sure what your bro was thinking, but wouldn't you rather have a 4 spd than a 3spd. the 700r is a 4 spd, the 350 isn't any different than what you have now, just more inefficient (meaning worse gas mileage.) And with the 700r, it's more than just the 4th gear OD. It's also got a great first gear. I don't know what your current 3 spd's first gear is, but the low gear in a th350 is 2.52 to one, it's 3.06 in a 700r4. that means quicker/easier acceleration off the line.
Bearing in mind that automatics are less efficient than manuals, (it takes more HP to spin them and they have slippage losses) have you considered staying with a manual? something like a t-5 from an s-10. I say this particularly because you have a six, if you had a 350 or whatever, I'd say go auto. with a 700r, you'll be looking at a driveshaft modification cause it's longer than your 3 spd, the th350 may be the same length as what you have, don't know about the t-5. the front yoke probably has a different number of splines. you'll need a different tranny crossmember.
Larry |
07-30-2011, 07:23 PM | #6 |
Re: Trans swap!
What kind of cross member would you need to add the 700r4 into one?
07-31-2011, 01:55 AM | #7 |
60-66 Nut
Re: Trans swap!
Any auto trans crossmember from a '63-'87 2 wd pickup or Suburban. You'll just need to drill the holes to bolt it in place in the frame.
07-31-2011, 11:22 AM | #8 |
Re: Trans swap!
awesome! Sounds like its a pretty easy swap to a 700r4.
07-31-2011, 11:38 AM | #9 |
Re: Trans swap!
Here are some pictures of me adding a 350 and 700r4 to my 66 We used a tubular bolt in crossmember since it left more room for the dual exhaust later.... http://kieth.smugmug.com/Trucks/66-G...23545979_r7nUc just click on the next thumbnail and you can see the progress .... this shows the changes we had to make for a manual speedometer drive. http://kieth.smugmug.com/Trucks/66-G...13173619_4TK8C |
07-31-2011, 07:40 PM | #10 |
Re: Trans swap!
if you are going to run the six and an auto trans you want to run the 2004r. this is because of the closer 1st and 2nd gears. the 700 has a big gap in gears from 1st to 2nd which the six does not like. go to inliners.org and they will explain it more
08-01-2011, 08:31 AM | #11 | |
Re: Trans swap!
08-01-2011, 08:45 AM | #12 |
Senior Car Nut
Re: Trans swap!
good point
Larry |
08-01-2011, 10:07 AM | #13 |
Re: Trans swap!
08-01-2011, 10:39 AM | #14 |
Re: Trans swap!
08-01-2011, 10:47 AM | #15 | |
Re: Trans swap!
Sam |
08-02-2011, 08:10 PM | #16 | |||
Re: Trans swap!
The T-5 bolted right up to the original bellhousing in the original 3 speed's place. Awesome thing about that is, you don't have to make a trans crossmember ! The difference in length is 7 1/2", so obviously I had to shorten the driveshaft that amount. Luckily my dad has a lathe and I can TIG weld ! Lol ! The output shaft is the same spline count, so you can even re-use the original yoke if it's useable. I was even able to use the original pressure plate and just use the Camaro clutch disc because it is 26 spline versus the 10 spline 3 speed. Quote:
It uses the same 4 bolts that the original 3 speed bolted up with. Works out perfectly because you don't have to fab a trans crossmember up. Quote:
I have a bunch of pictures if anyone is interested. By the way, I'm new here. Been lurking for a while. I guess I should go ahead and post my own Introduction thread. -Aaron |
08-02-2011, 11:58 PM | #17 |
Re: Trans swap!
pm sent Crash'd!
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air. |
Tags |
trans steering |
