Old 08-05-2003, 12:04 AM   #1
Kybol
Kybol's Avatar
differences between t-cases
What are the differences between the 203 205 and 208 cases? which ones are better then others, when were they used, I am asking about the 73-87 trucks. Thanks for the help.
-90 454ss http://www.imagestation.com/album/?id=4289115843
-04 TRX450R
-77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD
-82 c-10 SOLD
-02 CRF450 SOLD
Kybol is offline   Reply With Quote
Old 08-05-2003, 01:26 AM   #2
1969 GMC
1969 GMC's Avatar
the 205 is considered the "king" of t cases, it is strong all gear drive, but its low range isnt as good as some others. the 203 is full time, weighs like 75 pounds more than the 205, and is chain drive, but pretty beefy. i am not familiar with the 208.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-05-2003, 05:33 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The 208 has a chain also, but is not full time. It has an aluminum case some what considered inferior but has a 2.61 low range while the 205 is 1.96 and the 203 is 2.0. The 208 also has a slip joint output for the rear driveshaft also considered a problem since the TC fluid will leak out if you remove the driveshaft and try to drive w/ the front axle only. All three were found behind autos and manual trannies. While lower gears are not available for the 205 the thing to do is to take the gear unit from a 203 and mate it inbetween a SM465/205 combo with an adapter from ORD and have some seriously low gears.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
