Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-25-2011, 08:56 AM   #1
1971C10Blown
1971C10Blown's Avatar
91 S10 rearend swap
what rearend are people using in S10 for drag racing? the truck has a 7.5 10bolt, is it strong enough for the strip or will it just rip it self apart? also its not a posi and would like to make it one.
Jared
2014 Ram 2500 powerwagon
2006 GSXR 600
2012 Arcticcat proclimb 800
1970 C10 SWB 5.3LS turbo and 4L60E
"all throttle no bottle"
"Nitrous is like a hot chick with an STD, you wana hit it but afraid of the consequences"
"its not turbo lag, its for play"
1971C10Blown is offline   Reply With Quote
Old 07-25-2011, 12:59 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 91 S10 rearend swap
You can eithor grab a S10 8.5 10-bolt, or grab a ford 9 inch rearend.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-25-2011, 01:57 PM   #3
1971C10Blown
How can you tell the differance between the two rearends? the 8.5 and the 7.5?
Jared
2006 GSXR 600
Old 07-26-2011, 07:31 AM   #4
djracer
djracer's Avatar
Get a 9 inch if you think you ever want to go fast!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-26-2011, 12:59 PM   #5
Warrens69GMC
http://www.oldspower.com/vb/showthread.php?t=31398
Instead of the two points at the bottom of the Differential, you will have "squared off"
tabs
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-26-2011, 04:56 PM   #6
1971C10Blown
how are the ford 8.8 for strength? i found a complete rear end with 4.10 ratio and disks brakes for 1000 is that a good price? and its already sized up for an S-10.
Jared
2006 GSXR 600
Old 07-26-2011, 05:03 PM   #7
1971C10Blown
also i heard that a Nova rear end will bolt right in. Do you guys know what other 10 or 12 bolt cars will bolt into an S-10?
Jared
2006 GSXR 600
Old 07-27-2011, 12:03 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
The 8.8 will go in if you narrow the long side 3 inches and run 2 short side axles . I think ( dont quote me ) it comes out like 56 inches and the stocker is 54.5 . You'll need a bigger offset to make it work .
Personally , i would build a 9" . You can buy 33 spline axle and spool package from moser and use a stock case if your on a budget , but i suggest going 35 spline as the axles are basically the same price .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-27-2011, 01:23 PM   #9
djracer
djracer's Avatar
You can run 35 in a stock case you just have to have the right spool. Mark William was the only one that would work 20 years ago but i'm sure there are others now.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-06-2011, 12:33 AM   #10
gofastbobby
gofastbobby's Avatar
stock explorers came with that setup. you should be able to find them for around $400 from a boneyard. if i remember right it's a 31 spline axle and can also have the factory trak-lok (posi) to boot.
BTW, thats a hot setup for the rear end in Jeep Wranglers, so if you know any jeep guys they might be able to help you find one.
'76 C10 "BIG10" SWB 454/400 Mostly Stock.
gofastbobby is offline   Reply With Quote
Old 08-06-2011, 10:17 AM   #11
stich626
go to the junk yard with a measuring tape, after you've measured the s-10 spring mounts..
fyi.. exployer and rangers that have 8.8 rear ends , fall in. and the 8.8 is as strong as a 12 bolt (almost a copy really)
stich626 is offline   Reply With Quote
Old 08-07-2011, 09:38 AM   #12
C-10 simplex
If you can't find a 8.5 10 bolt from an S-10 extreme, you could use a 10 or 12 bolt from any car and just reweld the spring perches and then the wheels might stick out a little (or not if depending on wheel offset). i think it's cheaper/easier this way.
How fast are you trying to go?
2) P.S. i think Moser and others offer complete bolt in 12 bolts for the s-10 but that's big money (2K). i think you can get more use out of a 7.5 10 bolt than what is commonly thought.
C-10 simplex is offline   Reply With Quote
Old 08-07-2011, 01:50 PM   #13
djracer
djracer's Avatar
Two words. Nine inch
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-07-2011, 04:31 PM   #14
Magnimike1
Depends on power level but I suggest the Explorer rear(8.8), c clips though or the venerable 9"
Magnimike1 is offline   Reply With Quote
Old 08-07-2011, 08:10 PM   #15
stich626
not from a 2wd ranger or explorer.
I'd think there wouldn't be any "offset"
Old 08-07-2011, 08:34 PM   #16
djracer
djracer's Avatar
For some reason the pinion is way offset in the explorer 8.8's I would not run it the way it comes in a performance application.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-07-2011, 08:47 PM   #17
nomrlz
nomrlz's Avatar
this ^^^
if you're goin to the trouble to fab in a different rear end. make it worth your trouble
if you can find a direct bolt 8.5 for cheap then that wouldn't be bad if you're just building a moderate performer
nomrlz is offline   Reply With Quote
